05-30-2012, 02:56 PM
#31 (permalink)
aero guerrilla
Originally Posted by Gasoline Fumes
A slow-moving car was about to screw up my good coast, then I realized I could pass him.
YKYAHM when it takes you a moment to realise that you can also pass, not just be passed
The Following User Says Thank You to Piwoslaw For This Useful Post:
05-30-2012, 06:57 PM
#32 (permalink)
MPG Militia HMV-25E80+A
...When you have to change the shut off time of your MPGuino to 10 minutes, because you started EOCing for more that the 7 minute preset time.
05-31-2012, 02:35 AM
#33 (permalink)
It should stay on if it gets speed or injector signal.
05-31-2012, 08:44 PM
#34 (permalink)
No speed signal, and engine off for more than 7 minutes. I've been only using the GPH, trip total, and tank total function on my MPGuino.
Edit- My Jetta has a mechanical speedo.
06-01-2012, 05:46 AM
#35 (permalink)
maybe something helpful (made new topic so others can find it too)
http://ecomodder.com/forum/showthrea...tml#post309903
The Following User Says Thank You to meelis11 For This Useful Post:
06-04-2012, 10:57 AM
#36 (permalink)
Rat Racer
YKYAHM... When the guy riding your rear bumper is a school bus.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following 3 Users Say Thank You to Fat Charlie For This Useful Post:
06-08-2012, 03:45 PM
#37 (permalink)
Elise - '13 Hyundai Elantra GLS
You know you're a hypermiler if:
You've ever been passed by a Prius
You shift into neutral to speed up
You can drive for 10 minutes without touching the gas pedal (or using cruise control)
06-08-2012, 04:04 PM
#38 (permalink)
The Dirty330 Modder
YKYAHM....when you forget where you placed your fuel log in your car from not filling up
"The only real mistake is the one from which we learn nothing."
- Henry Ford
06-09-2012, 08:38 AM
#39 (permalink)
Check !
Check !
This part of the country is far too flat for that.
2 out of 3 ain't bad
The Following User Says Thank You to euromodder For This Useful Post:
06-10-2012, 02:07 PM
#40 (permalink)
aero guerrilla
YKYAHM if...
... All of the roads in your area seem much shorter when someone else is driving.
