Old 07-22-2009, 06:29 PM   #11 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Thanks! Awaiting patiently
Old 07-22-2009, 07:08 PM   #12 (permalink)
doviatt's Avatar
Grey Goose (Retired) - '89 Geo Metro LSI 4 door hatch back
Last 3: 57.16 mpg (US)
Tweety - '91 Geo Metro Convertible -2 Door convertible LSI
90 day: 43.97 mpg (US)
Shadow - '02 Honda Shadow VT1100
90 day: 43.46 mpg (US)
Sonic - '07 Honda CBR1000RR
90 day: 42.69 mpg (US)
Filmore - '84 Volkswagen Vanagon
90 day: 20.9 mpg (US)
Previous test did not just restore data as hoped.
I am making progress with CLI fdisk command though.
Could use more info. In the terminal type fdisk /dev/disk1 output should show geometry numbers and partition info. Interested in geometry numbers and start and size info for current defined partitions.
Old 07-22-2009, 07:26 PM   #13 (permalink)
Dartmouth 2010
SVOboy's Avatar
The result of that test
Old 07-22-2009, 07:42 PM   #14 (permalink)
doviatt's Avatar
I also discovered the command pdisk. fdisk displays the partition information and pdisk will allow us to change and edit the partition entries.
How is your time frame? Would your patience allow me to continue in the morning? Like I said I can do all of the experiments on my system to prove them out. The system is at work though and I'm headed home for now. I'd like to get you a working solution and then post the results. If you get more solutions posted in the mean time and you can wait I can test them on the sacrificial system here at my work. Just thinking of your important data. :-)
I love tackling these kinds of problems. Allows me to learn more about Mac OS.
LMK
Old 07-22-2009, 07:49 PM   #15 (permalink)
Dartmouth 2010
SVOboy's Avatar
I can wait. I may have shot myself in the foot by writing something to the drive without thinking.
I have tried the diskwarrior utility but it doesn't seem to want to do anything.
Old 07-22-2009, 07:59 PM   #16 (permalink)
doviatt's Avatar
Great. I'll check in with you in the morning.
Glad I can help. It is the least I can do....since I am about to pass you in the garage top 10 MPG standings.
I have done this procedure a couple of times on my linux box. Luckily I had the partition data written down. I just restored the start and size parameters of the individual partitions and it all came back. In your case it is just the 1 partition. No guarantees but at least we can prove it out 'works/doesn't work' on my Mac system first.
later
P.S. The summoning of any "real" Great and Powerful Mac Gurus is welcome.
Old 07-22-2009, 08:06 PM   #17 (permalink)
Dartmouth 2010
SVOboy's Avatar
Wow, I didn't even know I had made it onto the list finally
Old 07-22-2009, 10:50 PM   #18 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Bet you'll make a backup once you're done here, won't you?
Old 07-22-2009, 10:51 PM   #19 (permalink)
Dartmouth 2010
SVOboy's Avatar
Nope, it was just media I had collected over a few months on bit torrent, about 300 gigs. Already going about recollecting , just a pain
Old 07-23-2009, 01:21 PM   #20 (permalink)
doviatt's Avatar
Checking in...I haven't abandoned you or the cause.
Who would'a thunk I'd get distracted by actual work at work?
Update: current experiments have shown data loss with the repartition events. Shouldn't be the case if you just resized and added more partitions. The start sector of the 1st partition should not have moved or changed. This is the puzzling part.
You didn't change the partition type.. I'm sure there was no need. You just added more partitions at the end of the one big one. Has this drive always been 'Apple partition Map' type?
Just noticed... Its a Terabyte drive- wow! should have plenty of room for a while.
Restore oil additive... suspectnumber961 The Unicorn Corral 46 11-20-2018 12:15 AM
Weather data, MPGs and ABA Testing. TestDrive EcoModding Central 9 04-28-2009 06:58 PM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
Emissions Standards - "Good For Fuel Efficiency," Consumption Data Says trebuchet03 General Efficiency Discussion 11 04-18-2008 01:15 AM
Front VS Rear drive on electric bennelson Fossil Fuel Free 18 02-03-2008 03:10 PM
