Old 07-22-2009, 04:39 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Accidentally partioned a drive, how can I restore the data?
The partitioning took like, 15 seconds, so I know the data isn't actually overwritten. As such I am wondering how I can recover it.
Using OSX 10.4, any help?
Old 07-22-2009, 05:00 PM   #2 (permalink)
doviatt's Avatar
Grey Goose (Retired) - '89 Geo Metro LSI 4 door hatch back
Last 3: 57.16 mpg (US)
Tweety - '91 Geo Metro Convertible -2 Door convertible LSI
90 day: 43.97 mpg (US)
Shadow - '02 Honda Shadow VT1100
90 day: 43.46 mpg (US)
Sonic - '07 Honda CBR1000RR
90 day: 42.69 mpg (US)
Filmore - '84 Volkswagen Vanagon
90 day: 20.9 mpg (US)
How many partitions did you have?
You don't by chance have a copy of the original partition info (fdisk -l)...you could just put everything back (start and end sectors). If they were defaults you might be able to find these settings and reset them.
You are right your data is still there...just a bit inaccessible.
This info comes from a Linux perspective. OSX has similar tools and some times the same. Not quite sure about fdisk.
Old 07-22-2009, 05:05 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
It has fdisk.
However, I don't think I have the original partition info. It was just one big partition on an external drive, however, so maybe I can reconstruct it knowing that?
Old 07-22-2009, 05:14 PM   #4 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
If you have a sufficient amount of spare storage I suggest using dd to make a copy of the image. Like doviatt said, if you can figure out what the original partition info was, just go back into fdisk and change everything back. Offhand I imagine it's probably FAT or HFS, but you should probably double check that.
Old 07-22-2009, 05:15 PM   #5 (permalink)
doviatt's Avatar
The fdisk -l just lists current known partition info. Non destructive. Try this and post results. I have access to some Mac Mini's I can poke at to help trouble shoot and try destructive things to so you don't have to loose your info.
Edit: fdisk -l /dev/sdx/ (use sda or sdb etc if sata or hda hdb etc if ide)
Edit 2: ok the above doesn't work on mac. I'm still checking how they define their drives.....
Old 07-22-2009, 05:58 PM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
There is no fdisk -l command, says illegal operation.
I am on 10.5 now by the way, I just installed it in the last hour.
Thanks for the helping, trying to work it out
Old 07-22-2009, 06:05 PM   #7 (permalink)
doviatt's Avatar
The mac I have access to is sw_vers 10.5.3
I take it the subject drive is external?
Does the partition tab in disk utility show available space and Size being equal? If not drag the top of the blue partition window around.
Old 07-22-2009, 06:11 PM   #8 (permalink)
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
You could try Spinrite on it. this is not the primary purpose but it may work. You would have to pull the drive from the enclosure and temporarily install it in the main case.
GRC | Hard drive data recovery software
Good luck
Old 07-22-2009, 06:14 PM   #9 (permalink)
Dartmouth 2010
SVOboy's Avatar
This is how the screen looks atm in disk utility
Old 07-22-2009, 06:23 PM   #10 (permalink)
doviatt's Avatar
Cool. Helpful pic.
Ok you now have 3 partitions. One called Media one called Blank_1 and Blank_2 on your external drive.
I will try something on my system. Like I said I can do destructive testing on this and loose nothing. I will re partition an external single partition drive like you have with the 3. Then I will try to partition again with the 1 partition option. This should restore things to the way they were. Don't try this yet on yours.
I'll let you know the results.
Restore oil additive... suspectnumber961 The Unicorn Corral 46 11-20-2018 12:15 AM
Weather data, MPGs and ABA Testing. TestDrive EcoModding Central 9 04-28-2009 06:58 PM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
Emissions Standards - "Good For Fuel Efficiency," Consumption Data Says trebuchet03 General Efficiency Discussion 11 04-18-2008 01:15 AM
Front VS Rear drive on electric bennelson Fossil Fuel Free 18 02-03-2008 03:10 PM
