Old 05-19-2013, 10:48 PM   #1 (permalink)
Accurate instrumentation possible on a diesel?
In another thread, rmay635703 said:
Originally Posted by rmay635703 View Post
There is no fuel economy instrumentation available for diesels, unless you use the old manual thing from the 80s.
The scanguage will calculate FE on a diesel once calibrated so long as you drive one speed with one throttle position, deviate a little bit and the thing is WAY off.
I'd like to ask diesel vehicle owners what kind of instrumentation they're using, given this. My old 2007 Jetta currently has an UltraGauge and I'm a big fan. It would be a shame if I couldn't use it on my new 1999 F250.
Old 05-20-2013, 03:47 AM   #2 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
I'm using MPGuino on Berta, but it has FE signal comming out of ECU, so it was easy to make it work.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 05-20-2013, 05:03 AM   #3 (permalink)
Electronics made the things easier regarding fuel-efficiency instrumentation in Diesels, but with an old-school one it's still a challenge...
Old 05-20-2013, 05:07 AM   #4 (permalink)
AndrzejM's Avatar
True. Flow meters are expensive, and those cheap ones sometimes are just not good enough to measure FE accurately.
Old 05-20-2013, 10:04 AM   #5 (permalink)
...beats walking...
The 2014 Cruze Diesel has the same MPG display as its gasoline counterpart...and it just counts the number (and thus volume) of injection squirts (the diesel uses more than one) to estimate diesel consumption.
Old 05-20-2013, 12:27 PM   #6 (permalink)
1999 isn't that old, is it? The truck does have an OBDII port.
Old 05-21-2013, 08:38 PM   #7 (permalink)
The promotional material for the ScanGauge II indicates that it supports diesels. Is that just wrong? Or is there something about my truck that's unsupported. Still confused here...
Old 05-22-2013, 01:22 AM   #8 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
I have a ScanGauge II on my 2000 Jetta TDI and it does a reasonably good job of estimating the fuel consumption. Not perfect, but good enough to know how well I did on a commute or an errand. I normally run B20, and when I change to pure dino-diesel, the SG will get confused and will be off by a several MPGs. You can check out my fuel log; I've started to include the SG results with each fillup.
Old 05-22-2013, 03:56 AM   #9 (permalink)
If it's compliant to OBD-2 your truck might be supported.
Old 06-06-2013, 02:28 PM   #10 (permalink)
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
In a Mercedes OM 603 engine, there is a EDS control unit that is supposed to control the amount of diesel to be inyected by injection pump.
I have EDS scheme diagram. One should take advantage of it and construct a math model that calculates diesel fuel used, and together with speed, calculate mileage.
Mercedes 300 D turbo 1993
