Old 09-24-2008, 07:34 PM   #11 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
I have been using it for over 6 months now. Here are my results. I got a jump in Mpg's with as little as 10mL, which was 1mL per gallon. Since then I jumped to 1oz per 10 gallon or 3mL per gallon and saw a slight improvement. Anything over an oz per 10 gallon in my car and the car started doing worse.
Once my vehicle leveled out @ 44mpg, I decided to do a 9 tank a-b-a test to see what would happen. I got through six tanks before I got hit with a string of bad weather due to all the hurricanes skirting Florida, so I had to suspend the tests. As of right now I am back on the tests.
Honestly, I believe it works to restore your vehicles fuel system to "like new" operation. I did notice that it takes my car 2 tanks to react to whether or not I am using it. If at this time it is bumping my mpg's I'd say one or two mpg as opposed to the chunk it gave me in the begining. Check my fuel log, where I detail it quite well.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 09-25-2008, 06:15 PM   #12 (permalink)
Kawi - '04 Kawasaki Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Chevrolet Monte Carlo Z34
90 day: 26.52 mpg (US)
Mazda - '10 Mazda 3i
90 day: 35.15 mpg (US)
So at best it might help to use it once in a while just to clean out the fuel system, but using it continously is not really worth it.
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
Old 09-26-2008, 12:50 AM   #13 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
At best it shouldn't be used at all in your fuel system for safety reasons.
There are cheaper better detergents available at any auto parts store. Not only will they clean your fuel system better but the won't attack and degrade plastic and rubber parts in your fuel system. They are also epa approved.
Old 09-26-2008, 09:23 AM   #14 (permalink)
Wildfire - '96 Ford Bronco XL
90 day: 14.88 mpg (US)
Blackford - '96 Ford Bronco XLT
90 day: 20.26 mpg (US)
Y2k - '00 Honda Insight
Gen-1 Insights
90 day: 73.98 mpg (US)
Redford V10 - '01 Ford F250 Lariat
90 day: 15.64 mpg (US)
FireFly - '00 Honda Insight DX
90 day: 69.43 mpg (US)
LittleRed - '00 Honda Insight
I tried it for about 3 tanks, and saw no real results. My mileage can vary so much over the same route that 1 or 2 mpg change that acetone "might" wouldn't do it for me. If it gave me a 10% boost, then maybe it'd be worthwhile revisiting. My money is best spent on using the next higher octane fuel for a whopping $1 increase per fillup, and a 5-8% increase in economy.
MetroMPG.com mailbag: why don't you test acetone? MetroMPG General Efficiency Discussion 21 11-18-2014 05:00 PM
Acetone. Lets get to the bottom of this Nerys EcoModding Central 31 07-27-2009 01:55 PM
Adding Acetone as an additive to gasoline - worthwhile? havok95z71 General Efficiency Discussion 14 01-18-2009 11:29 PM
The acetone test trikkonceptz EcoModding Central 88 06-16-2008 10:27 PM
Video: The Crazy Thing About Acetone. Peakster EcoModding Central 10 01-15-2008 02:47 AM
