Old 03-04-2012, 10:53 PM   #1 (permalink)
help !!mpguino was working until yesterday
Hello if somebody can help my mpguino it was working fine until yesterday I don't know but for some reason now mpguino in the part where says GH before was saying GH000.13 and up but now suddenly says GH012.53 to GH012.58 so I don't know why and I check again all the connections and is fine the only thing that I notice is that all my injectors now has 12v even where it was connected the mpguino before it was 0v where I connected and now is 12v so how come? why ? I hope somebody can help me..
Paul.
Old 03-04-2012, 11:47 PM   #2 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Is only GH weird, or are all of your injector-related values wrong?
It's possible that you have a short somewhere, letting current past the resistor.
Old 03-04-2012, 11:57 PM   #3 (permalink)
Well I'm trying to check if there is any ground or short in somewhere but until now I can't find it.. the most important is that I now its not a serous problem with the injectors because from the ground ( from injectors )to to the Body its not shorten I put in buzz on my MM and there was not shorten ( otherwise will flood the engine )so the problem is in some where that I can not find it...I hope somebody can help me with this..
Paul..
Old 03-05-2012, 05:58 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I would go through and set the menu parameters back to their original values maybe.
Old 03-05-2012, 05:14 PM   #5 (permalink)
Thank you for the reply.. if you don't mind to give me what is the original parameters I don't have it and I try to find but there is not... thanks...
Paul.
