Old 05-17-2010, 01:11 AM   #1 (permalink)
30.67 MPG
carbonaltima's Avatar
Adding an electric motor to a gas powered vehicle
I've had an idea for a while now that I'm still working out. On a front wheel drive vehicle we could add an electric motor to drive the rear wheels. It could be mounted in the trunk and use a chain through a cut in the floor that would either connect to the sprocket on a modified axle or on the inside of the tire itself. We could use a fork lift motor. It would be sufficient for city driving.
Has anyone tried this. Did anyone use a different method for an ev hybrid project vehicle?
30 MPG is the FE equivalent of a 13 second 1/4 mile.
Old 05-17-2010, 07:54 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
yup, theres a few threads on various diy hybridizations. Borrowing a small 4wd or key components is a recurring thought too. I think coyoteX managed to get a motor connected to a driveshaft. There's probably a couple EV's that carry a small generator for that matter, though probably on the sly. Also there was a "5th wheel" approach that has been utilized, where a small wheel can drop down and push the car with electric power. And probably a few I'm forgetting.
Old 05-19-2010, 03:03 PM   #3 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
I have thought about that before my plan was to get the rear axle from a RWD V6 that matches the width of my Grandprix. Mount the motor to the axle and wire it up to a three way switch ICE-ICE/Electric-Electric and wire a relay that will start the ICE when the electric motor voltage drops below XX.
I never got anywhere on this as I do not have the money to do this on my DD or the cash to get a project car.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Can I use a GENERATOR to power an Electric car directly? Nerys Fossil Fuel Free 128 10-01-2012 01:24 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Hybrid Electric Scion xB trikkonceptz Hybrids 5 06-02-2008 05:14 PM
Homebrew Hybrid concept. Would it work? bennelson Hybrids 12 04-30-2008 03:30 PM
