Old 07-01-2011, 04:16 PM   #1 (permalink)
bellypan on only half
Hi all.
I have a kia picanto and so far have fitted a full lower grill cover. half upper grill cover. I have tried smooth wheel covers on the rear only by taping over the hub cap holes. So far all is good and i have seen a definate increase.
my coroplast is due to arrive this week and i intend to split a sheet and make full wheel covers for front and rear. I dont know what to do with the rest however. I did originally intend to belly pan but the problem will be the exhaust (do you normally split the pan to allow the exhaust open air?) and the suspension components. Towards the rear it would be easy to fit a pan straight across the underside. Would having only the rear covered cause any problems?
Or would an air dam be a better option and if so is their a specific height from the ground for best effect.
Old 07-01-2011, 05:27 PM   #2 (permalink)
belly
Originally Posted by momorris View Post
Hi all.
If you have the clearance,metal heat shields can be attached to either the exhaust or the upper surface of the pan.Or you can leave close quarters areas uncovered.Fiberglass exhaust header wrap can also mitigate high heat areas of low clearance.
As far as the pan itself,wind tunnel investigations have determined that one should start at the front and work back.
This morning I measured almost a 2-mpg loss due to removing the forward 1/3rd of my pan.Ouch!!!!!!!!!
Old 07-01-2011, 05:38 PM   #3 (permalink)
Thanks for the reply. Better start at the front then. I already run on LPG and was getting 450 miles from a tank (85 litres) after freeing up some binding brakes I saw 600. Wheels and grill gave 760 miles from 100 litres (I had to stick an extra £10 in) with some gas left. All of this has also been combined with an ecomodder driving style so I cant say what is due to the mods exactly but as long as its moving in the right direction im happy.
Edited to add: The last time I used exhaust wrap I was putting it around a pulse tuned header, how times can change.
Old 07-01-2011, 07:06 PM   #4 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Welcome!! way to jump in!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 07-01-2011, 08:36 PM   #5 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Have a look at these threads.
http://ecomodder.com/forum/showthrea...vic-16422.html This one's my own belly pan build, with some notes on how I dealt with the exhaust system.
http://ecomodder.com/forum/showthrea...how-15026.html
There's a ton of aero mod threads in the Project Library in the section "Project Section: Aerodynamic mods - fabrication", and more than a few discuss belly pans:EcoModder Project Library - EcoModder.com
Coast long and prosper.
