Old 09-12-2023, 06:51 PM   #751 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 51.04 mpg (US)
"it doesn't change, regardless of shape"- Speed??? between 20 and 250 mph
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
aerohead (09-14-2023)
Old 09-12-2023, 06:58 PM   #752 (permalink)
I read it as for any particular shape of varying fineness ratio.
Above 250, a pointed nose is better than a bluff nose.
The best accident is no accident -- Elon Musk
Old 09-14-2023, 10:57 AM   #753 (permalink)
' Cd / Shape / Speed'
1) the 'shape' determines Cd.
2) the Cd is constant within this velocity range ( this is 'low-speed, subsonic, incompressible-flow aerodynamics ).
Caveat:
You may see some researches, say, for some Teslas, which were specifically tested for ventilation drag for the different OEM wheels offered, which DOES alter the Cd slightly, however, the difference barely makes it onto to the 'radar screen' in relation to overall drag.
Precise road testing would respect these dynamics in order to parse out actual changes from R-R or aero mods.
Old 09-14-2023, 11:10 AM   #754 (permalink)
'pointed'
Correct!
Above 250-mph ( 405 km/h ) a road vehicle is entering transonic flow, where air begins to compress, and parts of the body may be capable of generating shock-wave drag.
Hucho gives us a glimpse into this world in his 2nd-Edition book, regarding record vehicles.
The rocket-powered 'Blue Flame' is attributed with a subsonic drag of Cd 0.20, which climbs to Cd 0.60, or 0.65 ( if memory serves me ) around Mach-1, in standard air.
You see the same with the Space Shuttle, North American X-15, and NASA lifting bodies.
The U.S. Army's Aberdeen Proving Grounds has published drag figures for a handful of artillery projectiles, which also depicts these exponential drag increases, from subsonic to supersonic velocities, at constant air density.
freebeard (09-14-2023)
Maximum angle for boat tail? abcdpeterson Aerodynamics 80 11-03-2021 12:55 PM
Aerodynamic Streamlining Template Part-B aerohead Aerodynamics 8 05-31-2013 12:23 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 01:32 AM
Aerodynamic Streamlining Template: Part-A aerohead Aerodynamics 0 07-18-2009 02:37 PM
All items I scanned in the new product showcase dremd The Lounge 0 11-08-2008 04:14 PM
