Old 05-05-2012, 11:15 PM   #41 (permalink)
TBD - '17 Toyota Corolla LE
Last 3: 36.26 mpg (US)
Starship - '08 Toyota Prius
90 day: 46.4 mpg (US)
Starship Resurrected - '08 Toyota Prius
Originally Posted by Sporty Modder View Post
Can you show /describe how it is attached now?
I added this floor section between the front bumper return and the louvered panel underneath the engine:
I then riveted two CF 'L' angles (at slight angle to centerline) that are about the full width of the newly added floor. They project vertically from the floor 2" and I added a 1" extension:
Old 05-05-2012, 11:34 PM   #42 (permalink)
Sport Compact Driver
Celica Gts - '84 Toyota Celica Gts
Sports Cars
90 day: 26.32 mpg (US)
The Bee - '96 Mazda B4000 4x4 Base
Pickups
90 day: 20.39 mpg (US)
Is the airdam mounted on the plastic blocker,motor/trans?
If the airdam gets moved foward it decreases your aproach angle, same as lowering it.
Old 05-06-2012, 12:43 PM   #43 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.21 mpg (US)
Originally Posted by woodstock74 View Post
That impact and abrasion resistant stuff is $8+/foot. I'm looking at the General Purpose PVC 4" width, $1.62/foot. As this is a "belt" I take it it has a lot of flexibility? When I think of PVC I tend to think of rigid (shatter prone in impact) PVC pipes.
Look at the belt thickness and minimum pulley diameter. This is industrial belting. They rate that stuff to run continuously for years.
The PVC belting is slightly over 1/8" thick and is rated for 3 inch pulleys. You would probably need to fasten it every 2 to 4 inches to keep it straight at highway speeds.
Old 05-06-2012, 01:10 PM   #44 (permalink)
Well I bit the bullet on it and put my order in. At this rate I have like $26 into this project.
Old 05-06-2012, 06:04 PM   #45 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
http://ecomodder.com/forum/showthrea...ces-16057.html
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 05-06-2012, 06:39 PM   #46 (permalink)
Originally Posted by BamZipPow View Post
I suppose I should ask, what makes this material difficult to work with? At least the link makes that suggestion...
Old 05-06-2012, 06:43 PM   #47 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Haven't gotten any to play with yet...but it is on my horizon at some point in time as my Coroplast side skirts will be at the point of no return some day.
Knowing me...I'll probably stack it on top of the side skirts I have now.
I would believe the belt doesn't have the same sort of "stiffness" as Coroplast does so you'll need to add in some support to keep it flexing over at the wrong point/place...
Old 05-06-2012, 06:58 PM   #48 (permalink)
I'll leave the 2" deep CF "L" support angle and just replace the 1" CF extension with the belt. Thus only 1" worth of belt will stick beyond the L angle. Will that be in need of support?
I still have to figure out extending the airdam. Going to investigate tonight and take the outer "diffuser" panels off and see what's underneath to see if there are any suitable mounting points for more support angles. Might be nixing the idea of moving the airdam forward to the bumper return; don't really feel like undoing what I've already done. And thinking of using the conveyor belt's flexibility to my advantage and create a extension from the current airdam, extending it infront of the tires.
Which reminds me...I have a really dumb problem. As this is a budget project and for now I haven't budgeted chassis stands to raise the car up while I'm working on the front, how are you guys doing any drilling under the car? My electric drill is too tall! I chucked my drill bit into my dremel and even that has way too much height for me to drill perpendicular into the underside of the car. I can remove my CF infill panel and drill off the car, but with my intention to extend the airdam I'm going to have to drill "in situ" utilizing hardpoints that are existing or that I bond/mount to the underside of the car...any thoughts?
Old 05-06-2012, 07:09 PM   #49 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
I built a frame fer my belly pans and used drop brackets attached to existing holes in my frame to secure it to.
I did the same thing fer my extended/dropped air dam as well...
My air dam thread...
Modified air dam... - Toyota Nation Forum : Toyota Car and Truck Forums
My belly pan thread...
Under belly pan... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2012, 09:53 PM   #50 (permalink)
JRMichler's Avatar
Cutting conveyor belting is about as much fun as cutting up a car tire.
