Old 07-24-2016, 07:44 PM   #1 (permalink)
Should I Remove My Heat Shield?
So my d15b7 has this heat shield on the exhaust manifold which I guess many engines have. From what I read I gathered that it's meant for lowering under-the-hood temperatures. Which translates to lower intake temperatures. Which in turn translates to more power. I'm thinking I should remove it because as an ecomodder I want higher intake temperatures. I would also save a fraction of a kilogram of weight. My question is are there any downsides to this?
Old 07-24-2016, 10:14 PM   #2 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Shorter battery life (assuming battery under the hood), reduced engine power, and increased NOx emissions to name a few. Try it and see if you can notice a difference.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Old 07-24-2016, 10:20 PM   #3 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
my concern would be 'too hot'.
if you try it and it get's too hot, then you cant reverse the harm done to all the small plastic parts and wiring.
but you are making a false assumption. the 'intake" is not from the engine bay. the intake comes from outside air. Heating up the engine bay to effect the intake is not correct. run a tube into the intake from the manifold.
Belive me, it gets hot enough in the engine bay as it is. adding 10% or 20% more heat will be destructive and not effective.
Hot is hot. Hotter is not better.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
