Old 02-20-2019, 01:09 PM   #61 (permalink)
1995 Previa LE S/C Driver
Guess it's good if you don't want to help anyone move!
I'm not a fan of the 3-wheel design, either, but the 1-passenger limitation means the adoption rate may be pretty low, and a Volt with 4 people in it will crush it in passenger-miles-kWHr.
The Following User Says Thank You to AlaricD For This Useful Post:
aerohead (01-22-2020)
Old 02-21-2019, 02:32 AM   #62 (permalink)
WHO NEEDS THE MOTORCYCLE WHEN YOU HAVE THE SIDECAR?
The Following User Says Thank You to Angel And The Wolf For This Useful Post:
niky (02-21-2019)
Old 01-22-2020, 11:59 AM   #63 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Not bad. the price point is reasonable for an electric single seater.
But it is still a 3 wheeler. Not overly stable in some curves.
I'd like to see it equipped with the Tilting Motor Works front end.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 01-22-2020, 01:58 PM   #64 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
I had always hoped the solo would come in a nearly identical duo, sadly not gonna happen and the “other “ fully enclosed 3 wheeler is unlikely to ever see light of day
Old 01-22-2020, 04:51 PM   #65 (permalink)
4-passenger
I don't know what your experience is,but around here,I witness,on a daily basis,a single commuter,in a four,or five passenger,multi-hundred horsepower vehicle on their way to work.
What an under-utilization of resources.Like myself! An embarrassment of riches,which would astound even the likes of Cleopatra.
Old 01-22-2020, 04:56 PM   #66 (permalink)
If you don't want to help anyone move[!] then just don't get an F-150 pickup truck.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
Old 01-22-2020, 10:02 PM   #67 (permalink)
The Solo thread is dead! Long live the Solo thread!
Between this, the Archie, the Can Am Spyder, and various used cars...
With snow in Show Low and Phoenix's heat, the enclosure sounds vastly preferable, and in Phoenix's summer I wear short sleeves and shorts, which means I would get a sunburn in the Arcimoto.
I drive my brother to the store a couple of times a week. It would be great if I could do that with vast efficiency, so there are definitely pros and cons.
Somehow a Spyder was involved in my ex's death. I know that she used to text and ride and didn't use a helmet. She sped and was in the fast lane, so undoubtedly she was going fast. Maybe she was focused, but got in over her head. I don't know, but I did not have a good impression of her trike before she died.
It seemed to break down significantly more than my Forester!
Here are the twenty-two steps to change the oil in a Spyder: https://www.spyderlovers.com/forums/...p-by-Lamonster
It takes 4.5 quarts of synthetic and the manufacturer says to change it every 3,000 miles. Is that normal for a "motorcycle?" Honda says to change the oil in my cars every 7,500 miles, it takes less for around 2l, and I just use the cheap stuff.
For some reason the crazy girl that drove her 1990 Civic 20+ MPH over the speed limit while staring at her phone, even in elk country, that was pulled over for suspicion of DUI, and rear-ended a truck and wanted sympathy (and prescription painkillers) unblocked me and got married.
We first met at a gym, but her Facebook profile is filled with pictures of her with food and drinks.
Hopefully he is a better driver and doesn't let her drive him anywhere.
I liked the two lunchboxes that I rented last year. I did not care for the other cars. I barely felt bad that I scratched the Hyundai, but it looks like USAA will not cover it because I did not keep collision after I turned in the car.
Don't you love dealing with insurance?!
Old 01-23-2020, 12:51 AM   #68 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Most motorcycle engines are unit construction so the engine and transmission share the same oil.
My BMW and Piaggio recommend an oil change every 6,000 miles. Some Hondas are every 8,000.
The most important oil change is the first one which is usually at 600 miles.
The Following User Says Thank You to JSH For This Useful Post:
Xist (01-23-2020)
Old 01-23-2020, 10:05 PM   #69 (permalink)
Ha. Back in the old days my '74 Honda 750 needed new oil every thousand miles or six months whether you rode it or not. The theory was that fumes from the gasoline would contaminate and ruin the oil even if you weren't riding.
JJ
Old 01-23-2020, 10:10 PM   #70 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
What was the interval on the original Mini? It had its gears in the engine oil, and they had to be a bit oversize because of that. BTW, that was a hack forced on Issigonis because they wouldn't build the flat four he had drawn.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
kach22i (01-25-2020)
