Old 07-22-2012, 06:27 PM   #1 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Another grill cover bites the dust
I was in my 1986 Jetta diesel fully loaded as usual today. Cruising at about 55 mph. the outside temp was 100 F with a slight tailwind. I notice that the temp gauge is getting hotter than usual. Nearing the 3/4 mark.
My grill cover was held on with two drywall screws and some cable ties. I pulled over and removed all of it. Within a mile the gauge was back down to 1/4-1/3rd the way up the gauge.
If the trade of more aero vs a significantly hotter engine is the trade then I am going to use a small amount of fuel more.
Usually August is hotter than July around here. It may go back on in the mid fall but not sooner.
Noah Webster, 1787
Old 07-22-2012, 06:39 PM   #2 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Have you considered optimizing the grille block opening ?
Old 07-22-2012, 06:50 PM   #3 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
size the opening in the worst conditions for it (basically now) and you wont have to worry about it. then you could tape it or have an easy to remove cover for the opening in the winter
Old 07-22-2012, 07:01 PM   #4 (permalink)
Do more with less
The optimum size is the stock opening for this weather and load. I am sure that the engineers at VW considered how much air is required at such load conditions.
Noah Webster, 1787
Old 07-22-2012, 09:46 PM   #5 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
actually it could be a little smaller opening since most manufacturers over design for the masses...
but you thought process is very correct Varn.
Let me throw this uot.
I travelled a great deal on a ranch road in my Infiniti Q45. The dust built up in the radiator. Even though I was my car religously, the fine dustg built up and caused overheating....even with two extra electric fans.
When I replaced the radiator......about 20 oz of dirt fell uot..........just sharing my experience.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Varn (07-22-2012)
Old 07-22-2012, 10:06 PM   #6 (permalink)
Do more with less
Yep I agree with your thought.
My car is 250,000 miles young. Is nearly 30 years old. I am one of the masses.
I travel regularly on dust covered roads. This year has really been a challenge. Our road is nothing but dust from the drought and heat. In four miles I can't see anything behind me.Probably my radiator is filled with dust. At least they put in a gauge instead of an idiot light showing that your engine is overheated.
I think I will get my power washer out and see if I can wash any dust out of the radiator.
Noah Webster, 1787
Old 07-22-2012, 10:24 PM   #7 (permalink)
mcrews's Avatar
The dust built up between the A/C radiator and the water radiator. There was a foam ring around the the two radiators that also prevented the dust from washing out.
Now when I spray clean the engine compartment, I stick the spray wand down between the two.
ECO MODS PERFORMED:
First: ScangaugeII
Old 07-23-2012, 08:44 AM   #8 (permalink)
90 day: 51.82 mpg (US)
Just FYI - careful about cleaning a radiator using high pressure - you can bend the cooling fins & make things worse. (Ask me how I know.)
Varn (07-23-2012)
Old 07-23-2012, 08:55 AM   #9 (permalink)
Do more with less
Good point. I have one that is gas powered and pushes water much harder than what I have seen at car washes. For now I have good enough cooling and too many projects to worry.
Noah Webster, 1787
Old 07-24-2012, 03:47 PM   #10 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Good Call
