Old 08-24-2009, 12:27 AM   #21 (permalink)
1991 RED Metro 1.0 Auto - '91 Geo Metro Lsi Auto
90 day: 38.28 mpg (US)
1991 3/5 2 door Blue/green - '91 Geo Metro
Last 3: 42.6 mpg (US)
Do you think side skirts are worth the work? I've been thinking about them but I haven't seen anything on how effective they might be.
Old 08-24-2009, 12:33 AM   #22 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
Testing grille blocking & wheel skirts: +5.7% improvement - MetroMPG.com
...der side skirts not wheel skits
Old 08-24-2009, 12:36 AM   #23 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
They will prevent potential cross flow from under to outer, and from outer to under - remember, the under belly of your car has several low pressure sections that might actually be pulling in air from the outer area.
You can also add inner and outer skirts which prevent air from getting to the tire faces at all, and help streamline the underbelly of the car after getting a belly pan.
Old 08-24-2009, 12:44 AM   #24 (permalink)
I was just looking at the aerocivics catamaran style skirts and that looks interesting.
I was thinking maybe the outside skirt angled from the inside back of the front tire and flaring out to both sides of the rear tire (long triangle like), enclosed in the center.
Old 08-30-2009, 04:42 AM   #25 (permalink)
Crono's Avatar
Pizza Geo - '92 Geo Metro
Last 3: 47.52 mpg (US)
Blazing Glory - '07 Yamaha C3
90 day: 108.96 mpg (US)
The Beast - '86 Pontiac Subird
90 day: 15.6 mpg (US)
Mom's Firefly - '92 Pontiac Firefly
90 day: 35.65 mpg (US)
Noris - '08 Toyota Yaris
90 day: 35.45 mpg (US)
Mirage - '15 Mitsubishi Mirage
90 day: 48.11 mpg (US)
Japan - '08 Suzuki Alto
90 day: 45.88 mpg (US)
The autos aren't too bad, and the 36mpg is the sort of mileage my mom gets in hers, and she is, by no means, an ecomodder. If you really want to go for the mpgs eventually going to standard would be better...though I'm not sure if it would be worth the work involved. (Though if you did you could always put the 4 cyl transmission and change other stuff while you were at it).
Old 09-01-2009, 11:29 PM   #26 (permalink)
I'm not much of a hyper-miler myself, Florida and an automatic trans don't present much of an opportunity for P&G or coasting so I mostly DWL and bear it. I'll probably get a MT car eventually but I want to see how far I can get this one first, would be nice to get to 50 but that's a ways off.
Last tank (most of a tank, 300 miles) came out to 40.88 MPG so I don't know if it was a bad tank or some of the mods are actually hurting FE. There were other changes at the same time as well though, I replaced a fuel tank that was full of rust which might have been creating some kind of lean burn condition due to it clogging up the fuel pump "sock/filter".
I'm going to put another tank through and then tape the part I cut off the rear back on and see what that does for a few tanks. Then maybe I'll remove the front air-dam and see what that does for a few tanks-at that point all the mods on the car will be ones that can't possibly be having any negative effect (wheel skirts, partial grill block and mirror delete).
Old 09-02-2009, 12:25 AM   #27 (permalink)
Added what I have written down to the fuel log here. I didn't do a very good job keeping track in the beginning but I'm getting better.
Old 09-03-2009, 06:07 PM   #28 (permalink)
Hey, nifty trick with the laser. I'll remember that one.
Keep us posted on your progress.
Finest regards,
troy
Old 10-05-2009, 05:05 PM   #29 (permalink)
Finally added some new pictures- cardboard Kammback, Frankensteined rear bumper cover and the latest battle scars.
Old 03-11-2010, 02:10 AM   #30 (permalink)
Just a little update (new pics soon)
I've installed Intax lowering springs and new struts all the way around, shortened the front air dam and the rear skirt parts that used to hang down so now I can drive anywhere normal cars do without scraping anything off.
Working on a permanent Kammback right now, trying to make something that works better than the cardboard prototype by making it as long as practical.
front spoiler airdam, geo metro automatic, geo metro wheel skirt, kamm kammback extension, side mirror delete
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 148 08-12-2021 10:53 PM
A few more small aero Metro tweaks; still improving MetroMPG Aerodynamics 11 06-06-2011 03:21 AM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Aero mod a convertible Metro? bbjsw10 Aerodynamics 2 11-02-2008 11:14 PM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 04:05 PM
