Old 08-15-2009, 11:05 PM   #11 (permalink)
1991 RED Metro 1.0 Auto - '91 Geo Metro Lsi Auto
90 day: 38.28 mpg (US)
1991 3/5 2 door Blue/green - '91 Geo Metro
Last 3: 42.6 mpg (US)
I must be like you then because I like it the way it is, fiberglass is such a PITA to work with. I even thought about leaving it all bare metal looking for even more of a "race car" feel but in the interest of less people asking silly questions I've decided to paint it so it blends in more.
If I was going to make a fiberglass cover I'd have to do the whole thing, factory part included and at that point I would want to change even more stuff to make it better. A guy has got to draw a line somewhere, it is just a Metro after all.
Old 08-15-2009, 11:28 PM   #12 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
LOL. I understand.
I personally love a clean line of connective rivets, especially when they're left metal tone after the rest of the part has been painted, and just clear coat put over them.
Old 08-17-2009, 07:15 PM   #13 (permalink)
non-issue
Originally Posted by robertwb70 View Post
Added some updates- Front tire deflectors, rear appearance panels and the upper part of rear fender skirts.
MadisonMPG- I drive mostly on rural roads to and from school and you can tell it doesn't like to go over about 60 MPH. I don't have a tach but I did the math and the RPMs are ridiculous at anything over 60 anyway so I just try to avoid the interstate; I do that regardless of the vehicle I'm driving so it's not a big deal for me.
aerohead- That thought did cross my mind but I can always get a better rear fascia from the salvage yard if it turns out to be an issue (this one is pretty rough so I think I did it a favor). The airdam on the front will probably make it a non-issue either way since there will be so much less air under there to begin with.
lost mpg with my CRX because of lifted valance is the reason I make the issue.
robertwb70 (08-18-2009)
Old 08-18-2009, 12:49 AM   #14 (permalink)
Thanks aerohead I'll keep that in mind I'm going to run it like it is for a while and later I'll probably swap a 92-94 style fascia on since I like that style better and it appears to be more aero too.
Spent most of the day today working on a bead/ flange roller/ shear tool from harbor freight trying to make it work right. Tomorrow I am going to weld some reinforcements on it and then I'll be ready to finish the fender skirts.
Old 08-18-2009, 01:19 PM   #15 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Looks good, should help FE too!
Winter daily driver, parked most days right now
Summer daily driver
Old 08-20-2009, 10:14 PM   #16 (permalink)
I've posted a couple of pics of an interesting method (to me) to figure out how to cut the sheet metal I'm adding to my car to match up with the complex curves with the minimum hassle.
I'm still working on the rear fender skirts and it's been slow going mostly due to me trying to get a little over ambitious with the design. School starts back Monday so I'm going to simplify some of the design to hopefully get it done before next week.
Also, and it might be my imagination, but it seems I have to brake longer/ harder to get the car to stop now, can't wait to see what the MPGs look like now.
Old 08-21-2009, 12:32 AM   #17 (permalink)
90 day: 53.56 mpg (US)
Winter beater Metro - '00 Chevrolet Metro
90 day: 61.98 mpg (US)
Fancy Metro - '14 Mitsubishi Mirage top spec
90 day: 58.72 mpg (US)
90 day: 61.46 mpg (US)
Nice to see another aeromodded Metro coming along!
Do the new deflectors ahead of the front tires actually stick out farther than the tire edge? I ask because I saw you wrote:
I made some extensions. This increases the frontal area slightly
If the tire sidewall is just visible looking straight on, that likely would have been fine, and wouldn't have increased A at all. The airflow coming off the bumper likely isn't flowing straight aft, so completely hiding the tires behind the plastic (or metal) isn't strictly required. (It's the same reason cars with front tire "spats" don't line them up with the edge of the sidewall.)
Latest mods: 3-cylinder Mitsubishi Mirage. EcoMods now in progress...
Ecodriving test:
Manual vs. automatic transmission MPG showdown
robertwb70 (08-21-2009)
Old 08-21-2009, 05:19 PM   #18 (permalink)
I don't think I was looking at it from the right perspective when I made them. I see what you're saying since the air has some momentum coming off the front of the car, makes me think maybe Suzuki did it right to start with?
Well modifications are always susceptible to further modification. Sooner or later I will have to remove the front treatments and when I do I'll scoot those in about an inch, trim 2 inches off the height of the air-dam and lower the front 1 inch, but for now I'm going top leave it and see what it does.
Old 08-24-2009, 12:03 AM   #19 (permalink)
Got the rear wheel skirts mostly finished today and posted some pictures, they still need a few adjustments but you can see what I have now.
Old 08-24-2009, 12:08 AM   #20 (permalink)
Instead of putting tire spats in the rear, why not make some side skirts and use the part that you've got there for a support/mounting location?
That will also allow you another area that you can add to your rear wheel covers, however many inches lower than it is now.
Just a thought.
front spoiler airdam, geo metro automatic, geo metro wheel skirt, kamm kammback extension, side mirror delete
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 144 10-21-2020 03:43 PM
A few more small aero Metro tweaks; still improving MetroMPG Aerodynamics 11 06-06-2011 04:21 AM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
Aero mod a convertible Metro? bbjsw10 Aerodynamics 2 11-03-2008 12:14 AM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 05:05 PM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
