Old 12-15-2010, 06:23 PM   #41 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Talking
Originally Posted by richtate View Post
I've got a 2001 GMC 1500 that I'm looking at modding, so this is a very interesting thread. Giving me great ideas for next summer. Looking forward to some real results with these latest mods. Thanks and keep up the good work.
Keep in mind that this test cap is only fer aerodynamic testing. Not moving on to a security aero cap until much later (if at all). One of my key goals is to make it so I can take it apart fairly easily...maybe 4 pieces (2 sides, top, and front support rail) plus the bolts/pins that keeps it all together.
Maybe I could have the completed shell parts Line-X'd fer a secure layer...
Where abouts in Texas are you at?
Old 12-16-2010, 07:49 AM   #42 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
If it works well, it'll be hard to take it off again
Old 12-16-2010, 08:06 AM   #43 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
The same could be said about my first belly pan...but I did.
I know I want a working hatch in the next version. Crawling under the current aero cap to git things is tough. Some angles on this version are not exact...so they have to be reworked. My main rails still have to be cut to the angles fer the side panels...
It might be tough to break down something that's working...but sometimes that's how you learn and move forward. BTW...that's why I shoot a lot of piccies.
I'll find out how well it's doing when the rain hits on Friday and I make my way to San Antonio fer the weekend. Hopefully the numbers will look better than before...
Old 12-16-2010, 01:29 PM   #44 (permalink)
BZP looking forward to seeing those numbers also! I was think more on the lines of a belly pan instead of skirts, so your testing is a boon to making that decision.
Old 12-16-2010, 02:23 PM   #45 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Talking
My belly pan thread at ToyotaNation.com...
My fuel log...
Old 12-16-2010, 05:46 PM   #46 (permalink)
BZP I'm in DFW area, I work in Plano and commute just over 20 miles one way. Needless to say, the fuel bill could be cut down some! Right now I ride my Harley when I can, but drive my truck if it's raining or to hot/cold.
Old 12-16-2010, 05:56 PM   #47 (permalink)
By the way, have you thought of putting wheel covers on? You could cut the coroplast or I was thinking of using clear plexy glass.
Old 12-17-2010, 08:05 AM   #48 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Does yer truck have stake holes? I'm gonna be zipping through during the holidays...might be able to arrange a quick meet and you can check out what I've done in person.
Wheel covers aren't on the high priority list at the moment although they are on there. I still have the rear wheel skirts to design and fab up after I do the rear aerodynamic mud flaps. I have enough coroplast to work with so I'd probably using those instead of buying some plexiglass/lexan. Just so you know...I'd probably make enough extras so I can spot glue the first set on and then rip them off when I need access.
Old 12-17-2010, 08:24 AM   #49 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Gitting ready to put in my side windows...clear cellophane wrap. The same stuff you would find in a flower shop. At least I'll be able to see out the right side again. I might have to git a roll so I can put some sort of covering fer the back, too.
Piccies after the install...
Old 12-17-2010, 11:26 AM   #50 (permalink)
90 day: 51.82 mpg (US)
Subscribed!
found another aero cap AeroAl Aerodynamics 5 05-19-2011 12:00 PM
Truck Aero, Bed cover DIY tonneau? Chris D. Aerodynamics 84 11-04-2010 11:56 PM
CLASS - 8 Truck Streamlining Benchmark aerohead Aerodynamics 0 02-28-2009 03:17 PM
CLASS-8 Truck Streamlining / Fuel Economy ( Part-1 ) Aero Specifics aerohead Aerodynamics 1 02-23-2009 05:16 PM
Yet Another Pickup Truck Aero Idea Big Dave Aerodynamics 14 05-03-2008 03:17 PM
