Old 07-23-2022, 11:55 PM   #531 (permalink)
90 day: 29.78 mpg (US)
No thought, smash the Edison.
Old 07-24-2022, 12:20 AM   #532 (permalink)
Aptera's New Gamma Exterior Renders --Aptera Owner's Club
Uninformed speculaton, but the renders raise some questions [not addressed].
There is a hiccup introduced in the door cut line below the rear-view camera.
Where are the front and rear license plates?
You can't be wise and in love at the same time. -- Bob Dylan
Old 07-24-2022, 12:38 AM   #533 (permalink)
It's technically an autocycle/motorcycle. So I'm guessing it isn't required by law to have front plates???
I try to be helpful. I'm not an expert.
Old 07-24-2022, 12:33 PM   #534 (permalink)
There is a trolley approaching, and you have your hands on a switch.
Tied to one track is Aptera. Tied to the other is Edison2.
What do?
Switch the track to take out the Edison2 then bring it back around and take out aptera, then crash the trolley into other trolleys.
Old 07-24-2022, 12:35 PM   #535 (permalink)
Concept vehicles don't worry about things like suspension and problems like "where does the license plate go".
Old 07-24-2022, 12:41 PM   #536 (permalink)
There would need to be room for one small plate on the rear, minimum.
Old 07-24-2022, 07:36 PM   #537 (permalink)
It depends on the state.
Looks like about 15 to 17 states require front and rear plate on motorcycles.
Probably something they should have considered from early on.
Figured out what states have the most ridiculous requirements and try to make sure there's enough lights for the highest light requirement, room for stickers as I'm going to assume there's some state or county with a requirement for additional stickers that don't go on the plate, make room for the bigest stupidest license plates, ect.
freebeard (07-24-2022)
Old 07-25-2022, 04:54 PM   #538 (permalink)
Some states Depends on hp. Below some number NV doesn't require plates like vespas and some scooters.
Old 07-25-2022, 07:15 PM   #539 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
The rear license plate goes on the rear. The front goes on the front.
But seriously, I recall seeing the old prototype having a license plate on the rear between the brake lights like. The front will probably have some sort of removable holder like all other cars.
Old 07-25-2022, 08:04 PM   #540 (permalink)
So if you reduce the CdA down to equivalent to a one square foot plate and you add a round-cornered rectangle....
