Old 02-17-2010, 08:07 PM   #1 (permalink)
cesardeluxe's Avatar
Audi a3 1998
I am thinking about ordering a mpguino as i don't have a trip computer.
All my efforts to visualize real time consumption were too much complicated for real life use... I connected a vag com cable to a computer, then sen't singal to a multimedia radio via a avermedia Vga to video converter, all this with the electrical adaptations due to voltage of different devices...
Picasa Web Albums - cesardeluxe
Now it is time to make it simpler
I have many questions
BUt lets begin with 2
can i get L/100km measure?
Where is VSS and injection on my audi?
Who knows maybe somebody can help
THank you a lot, i admire all i have read from you!
great web!
Old 02-17-2010, 11:05 PM   #2 (permalink)
I have found a pinout for the ecu
Bosch ME 7.5 ECU
http://www.me-mo-tec.de/content/down...?file=2011.pdf
i doubt if i should connect to it directly..i think i have to look for the wires located on the harness.. if i find it!
according to that
vcc is pin 2
and injection is 22
right?
by the way don't iso audio connectors to radio systems have a vss wire?
then i would need to get the injection cable only, where is injection plug in the motor? i should tap the one without 12v...
Old 05-01-2010, 03:23 AM   #3 (permalink)
The audi a3 has a vss wire to the radio system. That is what I know..
MPGuino for Audi rmccomiskie OpenGauge / MPGuino FE computer 40 05-22-2011 10:18 PM
A'right, time to try this stuff out a bit - '99 Audi A4 Avant Zyzzyx Introductions 4 11-21-2009 12:50 AM
Suggest me inputs for Audi 80 Jancis OpenGauge / MPGuino FE computer 6 03-28-2009 01:05 PM
new audi A1 grillblock lunarhighway Aerodynamics 3 10-02-2008 11:50 AM
Help with Audi Injector wire?(Not Audi specific?) secmil OpenGauge / MPGuino FE computer 3 08-09-2008 01:09 AM
