Old 08-20-2010, 10:05 AM   #21 (permalink)
autometer
I have used autometer on all of my trucks, I love them
Old 01-03-2011, 02:51 PM   #22 (permalink)
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
So...here is a qwuestion for you all....is 99.9 the highest mpg that can show up on these units, or are they limited to something lower. I WILL NOT get near that with my Geo, but have been getting from 52-61 depending on the conditions and how it is driven. I'd hate to buy something that has a limit of 40 or 50 mpg....anyone know?
AND...
I need to update my sig....the SRT4 has ran a 12.17 at 115 mph still on street tires and 93 octane fuel; the Voyager now gets 26 mpg with only replacemnt of the stock air filter with a three layer home made section of screen mesh; the Geo gets a max of 61 mpg, not 63....AND, I won the Stick Shift Nationals in October to raise my number of NHRA/IHRA Championships to 36, using my mechanics plain jane Neon while I was awaiting parts for the twisted in half input shaft on the SRT4 at the next to last race.
42 time NHRA/IHRA drag race champ
05 SRT4-12.17@117 mph on DOTs-31.0 mpg-SOLD
96 Geo Metro-3 banger-60.1 mpg-SOLD
95 BMW M3-13.41 @ 106 mph-31mpg-SOLD
77 Chevy Monza with 350/350-FOR SALE
84 Horizon-1880 lbs-29 mpg
95 Neon-43 mpg
99 Z28-10.80 @ 127 mph-27.1mpg
2011 Prius-62.1 wife's
Old 01-10-2011, 01:33 AM   #23 (permalink)
KLR650 - '10 Kawasaki KLR650
6.4 - '19 Ram 3500
All Black - '19 Kawasaki Vulcan S
Decelerating in neutral at 140km/h with the engine running I saw a reading of 292mpg in my old Pontiac Vibe.
On flat ground with a steady throttle at freeway speeds I can keep the instant mpg reading from jumping more then .2mpg.
I found that with my winter tires I had to up the EFF number to 93 to keep a relativly accurate reading.
If you're in Nebraska and the wind stops or you see a tree, pull over immediately and take a nap. You're having road hallucinations.
Old 01-10-2011, 08:24 AM   #24 (permalink)
Thanks...that's the info I was wanting.
95 Neon-43 mpg
Old 03-10-2013, 08:14 PM   #25 (permalink)
6.4 - '19 Ram 3500
Since I traded in the Vibe, the ecometer has had a new home on the dash of the Silverado. Still works great but one thing I noticed is that, in the Silverado, the instantanious reading doesn't jump around nearly as much as it did in the Vibe. That can probably be attributed to the fact that (at least with the manual transmission Vibe) the throttle is EXTREMELY sensitive to any change in position. 5spd stick w/4.31 final vs 4spd auto w/ 3.42 final. 2.66 times the displacement...
Still, for what it is and what it does, it works quite well.
Old 08-09-2013, 08:01 PM   #26 (permalink)
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
Autometer unstable?
I have a Factory computer onboard, and even starting my tripcomputer at 50 miles/h with cruise control (electronic), the instant fuel consumption is highly variable, even in an apparently flat pavement.
Only average mpg is representative. The other is illustrative as show you instant changes of pushing the trottle, climb or going down slope.
The fact autometer varies instante mpg means it is GOOD, not bad. If it didnīt varies its real time mpg, should be lying.
Oldbeaver
Mercedes 300 D turbo 1993
Old 08-25-2013, 09:29 PM   #27 (permalink)
Jumping fuel flow meter
Originally Posted by Old Tele man View Post
...ordered it on-line from Big Boys Custom Toys LLC, Enfield, CT...cost $74.50 USD including shipping & handling.
...I'm almost at the point of NOT recommending this device, because, so far, only the MPG-avg mode seems to work acceptably. The other three modes (MPG-inst, MPH and RPM) all "jump" around continuously, never settlling down on a fixed number, almost regardless of what the car/engine is doing.
...I don't know if the problem is with the unit or the car interface (2009 Pontiac Vibe 1.8L with CAN-OBD-II) and little help comes from Auto Meter (they were VERY prompt in responding before the sale, but are now disturbingly silent after the sale). I'm trying to find out if others are having similar problems either with the unit of with the unit installed on Pontiac Vibes and Toyota Matrixs and Corollas.
...the good news, however, is that once "calibrated" the MPG-avg reading displayed at the end of a tankfull of gas is quite close to the actual tank-fillup value.
...what vehicle are you thinking about installing it on?
Your meter is very accurate as instantaneous fuel consumption IS variable due to many factors. Only mean mpg tends to be stable in ANY good flow meter.
What are the connections it needs? Is it a OBDII meter? Or is it of more general use? Price?
Oldbeaver
Old 08-26-2013, 01:11 PM   #28 (permalink)
...beats walking...
The Auto Meter 9100 plugs into and uses the underdash OBD-II connector.
FWIW, the ScanGaugeII™ meter is MUCH, MUCH smoother in its displays of both instantaneous- and average-MPG values...and-d-d-d, it does NOT drain down the car battery when the car isn't used in a week.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
$70 OBD2 MPG Meter mazade Instrumentation 18 02-05-2012 09:05 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
PLX Devices releasing smaller $89 OBD-II MPG gauge MetroMPG Instrumentation 17 04-19-2009 06:32 PM
Analog MPG meter. jim-frank Instrumentation 11 09-19-2008 11:38 AM
