Old 02-10-2010, 11:55 AM   #51 (permalink)
Nice find, Neil.
Super secret lightweight A/C too (A/C required by AXP rules to keep interior temps below 95F). With a completely sealed passenger compartment! If a conventional compressor is too heavy, what's the plan?
The X-Prize probably doesn't explicitly prohibit a refillable dry ice compartment.
Probably going to use a stirling type compressor. If they do dry ice, I hope for the drivers' sake they at least put THAT in an atmosphere-vented chamber with a heat exchanger for the completely sealed cabin
Work From Home mod has saved more fuel than everything else put together.
Old 02-10-2010, 06:41 PM   #52 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Give me a sawzall and I'll make one efficient tadpole trike out of that thing !
I think the x-prize requires it to be a car. 3 wheels makes it a motorcycle.
Love this thing. I hope the sell a kit. :thumbsup:
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 02-10-2010, 07:50 PM   #53 (permalink)
suspension
Not sure about the door. Might check their gallery: Edison2: The Very Light Car (X PRIZE Contender) - Gallery - The Very LightCar
One thing I noticed: doesn't seem to have any (conventional) suspension.
Transverse composite leaf spring with locating links?
Old 02-10-2010, 09:40 PM   #54 (permalink)
I think it would be fairly simple to put a low drag passive fresh air system in; with the intakes in a high pressure or high velocity zone, and the exhausts into the trailing fascia (unless the engine exhaust is there, which it may well be...)
The front suspension is inside the wheel -- probably a trailing arm? The rear suspension is a trailing arm (that is also a cog & chain case) and the structural tubes pivot in two large diameter bearings on the inside end, and there is a spring/shock unit there. So all the wheel travel is provided by trailing arms; and there is no vertical motion in the horizontal airfoil struts that join the wheels and the chassis.
Old 02-11-2010, 12:02 AM   #55 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
They say they're going with the 5 gallon tank instead of the 3 gal, to achieve the 200mi range required by the X-Prize rules. That's less than 66 miles per gal of ethanol, or < 78 mpge.
Old 03-13-2010, 01:54 PM   #56 (permalink)
Loads of new pictures from first day testing at the track:
Edison2: The Very Light Car (X PRIZE Contender) - Gallery - NCCAR TestDay
Old 03-13-2010, 03:15 PM   #57 (permalink)
I've always wondered how wheel fairings "fare" in x-winds...
Old 03-13-2010, 04:32 PM   #58 (permalink)
...beats walking...
...obliquely, I'm sure.
Old 03-13-2010, 06:11 PM   #59 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
In a crosswind, front disk wheels on bicycles are very hard to control, due to the center of pressure being ahead of the usual axis of rotation. This car seems to take that into consideration somewhat, with the extended tails on the fairings. Cars have better gyroscopic and inertial stability anyway. As for side force, the shape has turned from an inefficient monoplane lifting body to a triplane with two or four fairly low-aspect ratio wings added.
Old 03-13-2010, 08:51 PM   #60 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Frank -
Would it be fair (or fare? ) to say that the issue depends on where you live? In Los Angeles the frequency of windy days doesn't make it too much of a problem. On the other hand, if I lived in wind-farm country, I am guessing that I would have problems.
CarloSW2
American Solar Energy Society
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 01:21 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-21-2012 12:34 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 09:38 AM
Automotive X Prize - would a modded Civic VX make it? Krieg EcoModding Central 31 01-02-2008 08:06 AM
