Old 11-05-2008, 12:13 PM   #1 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
EV Dodge Neon Conversion
Hi Everyone!
My new friend Tom G. is converting a Dodge Neon to be a 300+ volt AC electric car.
We are going to be making videos showing how to do a car conversion, and post them on YouTube.
I will start off by embedding videos here.
Perhaps we could get a LoveJoy sponsorship out of this one!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 11-05-2008, 02:22 PM   #2 (permalink)
90 day: 51.82 mpg (US)
Great idea, Ben!
I have to repeat a tidbit a professional EV builder told me a week or so ago, which was a warning against using Lovejoy couplers in high powered conversions. He seemed convinced they would wear out the spider. I can't say whether that's true or not, and didn't think to quiz him on what type of spider material he was talking about.
Old 11-05-2008, 02:26 PM   #3 (permalink)
Meh, as long as the coupling is big enough (or designed for the torque) its fine. We use generally the same type of coupling in the conveying industry and we're transmitting thousands of ft/lbs of torque.
Old 11-05-2008, 02:28 PM   #4 (permalink)
Meh, I stand corrected then.
I have heard of a lovejoy failing on a low-power EV though (72v). Can't say why, of course.
Ben's going to become famous with his video series. His friend Tom, too.
Old 11-05-2008, 02:39 PM   #5 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
This is, of course, just the first of many videos.
Comments like asking if a Lovejoy coupler works or not are all appropriate questions.
A big part of these videos is to encourage discussion of vehicle design, and encouraging others to get out there and do it!
My YouTube Videos
Old 11-05-2008, 02:55 PM   #6 (permalink)
Well, I can't speak for the love joy specifically. Ours are a bit different in design and are made to handle the torque (up to 11,000 ft/lbs or 15,000 Nm).
rexnord.com | Wrapflex
Old 11-05-2008, 04:17 PM   #7 (permalink)
Misanthropologist
captainslug's Avatar
BORK! - '89 Volvo 240 DL Wagon
90 day: 21.27 mpg (US)
I wouldn't worry about the Lovejoy so much as I would relying on such a small end-face seam weld for power transmission. It might be more prudent to use a larger spline size lovejoy and lathe it to match a slightly larger size, then mill the spline adapter to include a keyway.
Of course that really depends on how much force it took to press the spline bushing into the lovejoy before you welded them together.
Relevant project link where the motor and transmission were coupled by interference fitting a spline adapter onto the motor shaft. Part was precisely machined so that it could be heated, pressed onto the shaft, and then cooled.
http://evdrive.com/BMW_project/ACmotor.html
Old 11-05-2008, 06:30 PM   #8 (permalink)
Finally at home so I can view the video. Very nice!
Old 11-05-2008, 09:46 PM   #9 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
pretty cool. I was always curious how to do this. I agree with CaptainSlug, I would have expected a keyway ground into the spline off the clutch plate, but as long as the welds are strong enough, it doesn't matter!
Does the electric motor drag at all when you shut it off? I thought the EOC-ing would still be something you'd want to do if you could, and wouldn't that allow you to change gears? Of course, putting a clutch on that would be very hard.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 11-05-2008, 09:50 PM   #10 (permalink)
gascort's Avatar
Oh, and thanks for the video. We will look forward to future installments!
AC Dodge Neon Electric Conversion Videos bennelson Fossil Fuel Free 57 10-24-2011 11:25 PM
Newb - better MPGs out of a Dodge Neon? stevewww EcoModding Central 7 10-21-2011 08:50 AM
Riley's EV conversion WannabeEVer Fossil Fuel Free 3 06-28-2008 12:47 PM
Practical? Possible? Taurus EV Conversion WaxyChicken Fossil Fuel Free 30 01-17-2008 11:12 PM
