Old 11-04-2009, 10:40 PM   #1 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
Reverse Lights Not Working On Cold Start
Ok, so I have sort of a weird problem going on. The reverse lights on my 1998 Jeep Cherokee 4.0L don't seem to want to come on when the engine is cold and it's the first start of the day just outside my house. Once the engine warms up they work fine, so it's hard to recreate the problem. Is it a sign of a dying relay or something else? Just looking for ideas of where to look first. Thanks!
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 11-05-2009, 12:38 AM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I don't think there is a relay for the reverse lights, it's just a switch in the transmission and a fused power from the fuse box.
When the vehicle is cold, pull the switch out and actuate it manually while watching via a mirror to see if the lights come on or not.
Old 11-05-2009, 12:22 PM   #3 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Sounds like the switch. It might be getting old and worn out and the contacts might be getting frosty. Maybe wiggle the shift lever and see if it makes the lights work. Or it might be a bad connection somewhere too, even a bad ground.
Winter daily driver, parked most days right now
Summer daily driver
Old 11-05-2009, 12:53 PM   #4 (permalink)
Looks like you guys might be right about the switch. I did a little more checking on the internet and found the Cherokee uses a Neutral Safety switch to control the reverse lights. So I figure go get a new switch right? Problem is that switch costs $340 Can we say highway robbery? The good news is I found a great write-up about how to remove and clean the switch to get it back to good as new "NSS Rebuild". So I guess it's on the to-do list.
Thanks for the help guys
Old 11-05-2009, 02:33 PM   #5 (permalink)
Until you get around to that, you can tap in a toggle for the reverse lights, just make sure you don't leave it on while you're driving.
Old 11-06-2009, 12:58 PM   #6 (permalink)
wagonman76's Avatar
Team Chevy
And there's always the junkyard too.
Summer daily driver
start a "Fire" fly EV project Trevs Introductions 17 06-25-2016 12:14 AM
Disconnected Idle Air Control - for lower RPM after a cold start Lazarus EcoModding Central 19 04-15-2011 03:50 PM
Winter cold start & idling warm-up experiment MetroMPG Hypermiling / EcoDriver's Ed 17 12-17-2010 03:39 PM
Help me disable my daytime running lights for more fuel efficiency.... blackjackel EcoModding Central 7 07-27-2008 10:27 PM
Why won't my truck roll start cold? extragoode Hypermiling / EcoDriver's Ed 8 05-25-2008 08:22 PM
