Old 05-11-2013, 04:00 PM   #1 (permalink)
My C-Max - '13 Ford C-Max SEL
Type of heat shielding for pan under muffler?
Hey Guys,
Question;
When making a belly pan, heat shielding is important around the exhaust. This we all know. However, in looking at my pan idea/design, I was considering using simple foil tape used by HVAC guys to tape exhaust vent tubing on furnaces.
What are your thoughts on using this to protect Coroplast?
Matt
Old 05-11-2013, 04:38 PM   #2 (permalink)
tape
Originally Posted by Recumpence View Post
Hey Guys,
Question;
Matt
My thought is that foil is designed to reflect ultraviolet light before it can be converted to infrared and that the tape would eventually transfer heat to the plastic.
If you had an actual metal skin attached with standoffs,with a dead-air space in between,it would better shield the plastic.Like a double,or triple-wall stove pipe on a wood stove,or heat-shield under a catalytic converter.
Old 05-11-2013, 04:47 PM   #3 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
please see the link in my signature on belly pan....very useful pics.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 05-11-2013, 05:01 PM   #4 (permalink)
Hey Guys,
Question;
Matt
I'd rather ceramic coat and then wrap the exhaust...
Wolf_Tm250 [Silat-Kali] - Parma (Italy)
Suzuki Gsx-R 600 naked
Toyota Rav4.1 Torsen: 240hp 3SGTE swap in progress
Toyota Celica Gt-Four ST205 Snowy White [2.34kg/hp - 600Nm@4950rpm]
EFI University Advanced Tuner
Old 05-11-2013, 05:08 PM   #5 (permalink)
mcrews's Avatar
Hey Guys,
Question;
Matt
Matt,
how many threads have you researched?
after you have, then let's discuss what you have seen.
NO ONE, I repeat, NO ONE has reported melting coroplast. ....wonder why?
ECO MODS PERFORMED:
First: ScangaugeII
Old 05-11-2013, 05:39 PM   #6 (permalink)
Thanks for the input, guys.
I have been reading up on belly pans and all I seem to see in each thread is "Coroplast will deform from heat".
I would love to have an airspace between the heat shield and the pan, but there really isn't any room. Maybe I could manage 1/8 inch of space. Of course, any air space is good.
Matt
Old 05-11-2013, 08:48 PM   #7 (permalink)
mcrews's Avatar
1. when deciding to do a belly pan you should look and see if you can seal it. That would mean you have clearance low enough below any exhuast.
2. when I did mine, I realized that the exhaust system was parallel with the pan so I cut the belly pan to go right up to the exhaust pipes. Then in the rear, I created a screen shield that would allow the heat to escape.
if you only have less than 1/8 of an inch, then why cover it and intentiionally create a heat problem?
for example: in my full body underbelly, IF I had enclosed the entire underbody would I have gained 1 more mpg? I really dont think so.
Proof? when I removed the center section after 1 1/2 yrs, I did not lose any mpg.
without a picture, it's hard to help you make your desicion, But I would NEVER close off the underbelly 100%.
Look at all the top of the line factory underbelly pans. I have the 2013 Audi A8 in my thread. They leave the exhaust exposed.
Again, the rear underbelly, which I used the screen material, was on the Q45 till I sold it.
here is how close the corplast is to the rear exhaust:[
you can see the exhaust on the far edge of this picture, see how close the coroplast is? how it was cut to follow the lines of the exhaust.
ECO MODS PERFORMED:
First: ScangaugeII
Old 05-11-2013, 10:20 PM   #8 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
i used about 4 inches of fiberglass insulation for my full underbelly pan on a 93 festiva. so far no warping or melting issues
Old 05-12-2013, 04:20 AM   #9 (permalink)
