Old 01-04-2010, 03:31 AM   #1331 (permalink)
jackbauer's Avatar
Or wire em up via an opto to run defunct engine related dash lights such as oil pressure and alternator.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
MPaulHolmes (01-04-2010)
Old 01-04-2010, 09:51 AM   #1332 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Yep, I am familiar with a couple different ways that a person could remount an LED or otherwise direct it's light, but I didn't have any of those things, and a drill just works SO WELL. That, and low-tech will beat high-tech EVERY time.
Here's a video of my software upgrade:
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-04-2010, 06:20 PM   #1333 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Here's the new configuration for my car with the main contactor and a few other things in the front of the car inside a weatherproof box.
My YouTube Videos
Old 01-04-2010, 06:27 PM   #1334 (permalink)
Wooo, getting all fancy on us now I see! Good stuff Ben.
Is that the contactor I gave you? How does it compare to the one you were using?
Old 01-04-2010, 08:40 PM   #1335 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Yeah, that's the 12 volt one you gave me.
It doesn't look quite as beefy as the 24/36 volt one I was using, but it's still pretty decent. There was a bit of char on the contactor points, which I cleaned up with some sandpaper, but those should eventually be replaced. I should check to see if the parts happen to be interchangeable, and put the best together....
My YouTube Videos
Old 01-06-2010, 02:07 PM   #1336 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
How big of a piece of plastic do you need as a cover? I may have some I could mail out to you.
Old 01-06-2010, 04:01 PM   #1337 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
The big box with the contactor and fuse already has its own weather-tight cover.
What I would want plastic for is to make a custom cover for the Open Source Controller.
I am having someone check on a "plastic bender" which would allow a piece of plexiglass or Lexan to be bent into the same shape as the existing sheet metal cover on the controller.
I already have some scrap plexiglass around, so I really don't need anyone to send me anything.
I would love to have a clear cover for the controller, as it would let me see the indicator LEDs inside AND show off the cool guts of the controller.
My YouTube Videos
Old 01-06-2010, 04:04 PM   #1338 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Ben -
Can you cut a hole in the metal cover, a'la custom computer cases, and install acrylic on the back side? You could even put in some LEDs or CCFLs and make a sweet little controller... might attract the "younger" crowd a little bit?
Here's a walkthrough for something similar:
MetkuMods - Because you love your hardware!
Old 01-06-2010, 04:14 PM   #1339 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Yep, that could be another possibility.
I do have around two strips of green LED lights, which run on 12V.
I was originally thinking about installing them in the back of the car, but since I have both a controller case AND a case for the contactor, fuse, etc, that means I could have one very cool green LED strip inside each case!
My YouTube Videos
Old 01-06-2010, 04:16 PM   #1340 (permalink)
YES!
I just like modding things more than replacing parts, I guess. That site has walkthroughs for alot of mods, ranging from easy to ninja.
electric car, electro metro, geo, metro
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 36 02-11-2015 11:08 AM
Daox's 1997 Paseo Build Thread Daox EcoModding Central 241 11-12-2013 11:23 PM
DPoV's Jeepin' Build Thread DifferentPointofView EcoModding Central 26 12-16-2009 04:31 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Margo II: the build (project thread) AndrewJ Alternative Transportation 26 04-23-2008 01:23 PM
