Old 07-15-2016, 01:07 PM   #1 (permalink)
roof shingle for air damn?
Greetings,
I had to replace a few shingles on my roof. I only needed like 2 of them, but they come in 50 packs. Anyway, I was thinking of using some to make an air dam. They are about 1/4 inch thick, and they are waterproof. I would attach them with screw and/or pop rivets.
Each one is about 12 inches wide and 3 feet long. I was thinking of cutting one in half length wise and attaching them end to end, with another half cut riveted to the back side to help hold them together.
Any thoughts on using these for an air dam, front lip, and/or tire spat?
The Following User Says Thank You to 87jeep For This Useful Post:
aerohead (07-15-2016)
Old 07-15-2016, 02:27 PM   #2 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
There is no real structural reinforcement to a roofing shingle. As the material heats up, it will git weaker. As it gits cooler, it will become more brittle. I don't think roofing shingles would be a good choice fer an air dam, front lip, or wheel spat.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
Old 07-15-2016, 04:46 PM   #3 (permalink)
Just an invitation for some kid to kick it or some drunk to back into it. If it at all looks vulnerable or prone to damage someone will test it, just for kicks.
Everyone in the world will be out to teach you a lesson for your own good and demonstrate the error of your ways to you.
It's one of the darkest aspects of human nature I'm afraid.
I call it the "six year old boy syndrome", will it break or not...........let's give it a try.
Old 07-15-2016, 06:00 PM   #4 (permalink)
shingle
I agree with the others that they might not be such a good choice.
While fiberglass reinforced,the asphalt matrix is almost granular.It has little tolerance for tension,is prone to tearing,and 'creeps' when heated.
The material is also kind of heavy and it's dead weight would always challenge any fastener attempting to hold it.
And without some sort of structure like lawn edging has,built into it,it would likely deform in the airstream and not rebound once the aerodynamic load was relaxed.A ground strike on a driveway ramp might destroy it in compression,buckling and tearing it.
If it could be done in a continuous curve it might survive for a while.Hard to say.
Curiosity might kick in?
BamZipPow (07-15-2016)
Old 07-15-2016, 06:17 PM   #5 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
That'll fail in fairly short order.
Go to Tractor Supply and get some baler belting. Similar texture, genuinely sturdy. Or Home Depot for some lawn edging, super cheap and tough enough.
The Following User Says Thank You to elhigh For This Useful Post:
