ARG!!!
I had planned on doing the Power Steering delete this weekend, but
A) the water pump is on the same belt, so I couldn't remove the belt
B) There appears to be more than just 2 hoses connected to the power steering pump.
Here, two hoses can be seen, in addition to another hose (not pictured) connected between the resivoir and the pump. I guess I'm going to have to buy the service manual to determine how to do this. Even if I find out what to do, the pump is in the back and is practically inaccessible. Perhaps I should get some jack stands and attempt to access it from below.
On the upside, since I wasn't able to do the power steering delete, I decided to do a little aero modding.
I did a partial grill block and belly pan - not sure if I can really call it a belly pan - it just extends from the bumper to just past the radiator where a deflector already existed.
Before:
After:
I haven't done any ABA testing to truly determine the effectiveness, but my gas mileage has been pretty consistent over the past few days, so I should be able to estimate.
Another interesting thing to note is that my UltraGauge has been telling me about pending trouble codes, so I finally got around to checking them today. One of them was P0174, which indicates that the system is running too lean, which might be a contributing factor to my higher gas mileage. I intend to get it serviced, of course, but I'm wondering just how bad something like that could be as long as I'm not having trouble with it sputtering.
