07-09-2009, 01:20 PM
Removing decals?
As most have seen, I just picked up a Prius. On the back, the dealer of course had to slap his decal on. I don't like it and want it off. Chalk it up as a weight reduction if you want to.  I just don't like it. So, what is the best way to remove a decal?
07-09-2009, 03:56 PM
aero guerrilla
Warm it with a hair dryer, or let it warm up in the sun (with the careful help of mirrors or lenses) if you don't want to use electricity. Then try to 'floss' it with fishing line. I'm thinking of doing the same with a few decals I have, and that is the answer I got when asking around.
07-09-2009, 07:55 PM
Harebrained Idea Skeptic
"Flossing" works on foam-adhered badges, but it won't work well on a decal.
If a hairdryer doesn't do the trick, get some General Purpose Adhesive Cleaner #051135-08984 from an auto body supply shop -- it will dissolve the glue without harming the paint. It's a great solvent for working around the car, so you'll find other uses for it as well.
07-09-2009, 08:39 PM
EV OR DIESEL
Heat + plastic paint scraper and maybe some solvent.
!!!!!NOT SOLVENT + HEAT!!!!!!!
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
07-09-2009, 09:45 PM
Hi-Tech Redneck
Heat is the trick and then a good fingernail will work it off without damage. After it's removed, buff it.
GeoMetroforum.com - got mpg?
07-10-2009, 12:12 AM
if it's one of those thick plastic ones, just peel it off with fishing line or something, then use goo gone and a cloth to remove the remaining stuff.
if it's a normal decal, you can buy a rubber wheel that goes on a drill and will be amazingly effective at removing it. Goo gone for the remainder.
Some polish and wax after and it'll probably disappear.
07-10-2009, 12:46 AM
My Goal: 35 MPG All Day
I JUST posted a post like yesterday, of me removing all the badges on my car, I sprayed it with goo gone, let it sit for a few seconds and got some thread and flossed all of them off, really easy... http://ecomodder.com/forum/showthrea...tyle-9154.html was my post
07-10-2009, 01:30 AM
Eucalyptus oil is another eco friendly oil which happens to be great for removing glue residue from decals etc.
Cheers , Pete.
07-10-2009, 07:05 AM
#9 (permalink)
Dartmouth 2010
Sand-blaster! I hear the rough surface will make the paint like a golf ball and therefore more aerodynamical!
07-10-2009, 10:37 AM
#10 (permalink)
Master Novice
Bad Yankee! No Chowder!
