02-20-2014, 02:13 PM
#151 (permalink)
T-100 Road Warrior
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
02-28-2014, 08:21 PM
#152 (permalink)
T-100 Road Warrior
03-01-2014, 03:43 PM
#153 (permalink)
T-100 Road Warrior
03-01-2014, 04:24 PM
#154 (permalink)
Lots of Questions
Does the aerocap rest on the top of the trailer butted up against the sloped part on top?
Also, are you going to paint everything when all is said and done?
Excellent work so far, keep it up!
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
The Following User Says Thank You to jeff88 For This Useful Post:
03-01-2014, 04:32 PM
#155 (permalink)
T-100 Road Warrior
The aero cap can't butt up against the sloped part of the trailer or it will impact it when the trailer pivots/pitches (up/down) around the hitch. If you look back a few pages, you'll see where I jacked up the rear of the trailer to see how far the trailer can pitch up before the front of the lid impacts the aero cap.
Not sure about painting it yet. This is only a design/shape test so far. I still have a long ways to go before I build it to a point where I might paint it. I might throw a quick cover of flat black on it but that would just mean I would have to rely on the reflectors fer people to see it. Maybe a zebra pattern on the trailer in the meantime...
Thanks fer the encouragement!
The Following User Says Thank You to BamZipPow For This Useful Post:
03-01-2014, 05:02 PM
#156 (permalink)
T-100 Road Warrior
Post #86 is where I jacked up the rear of the trailer (fiberglass tub installed)...
http://ecomodder.com/forum/showthrea...tml#post403430
03-01-2014, 09:41 PM
#157 (permalink)
Lots of Questions
Thanks, somehow I missed that post.
I'm just wondering what you plan on doing with this area, or if it even matters.
The first thing that came to mind are those brush type things that allow things to go through them. Like these:
Best EM Quotes:
The Following 2 Users Say Thank You to jeff88 For This Useful Post:
03-01-2014, 10:20 PM
#158 (permalink)
T-100 Road Warrior
Oh...that gap.
I'll attempt to reuse the poly gap cover I used in December's trip to Jacksonville, FL and see if I can make it work with the new lid. You can see what I did starting at post #111.
http://ecomodder.com/forum/showthrea...tml#post404367
If that works, I might try to build up the transition area behind the gap cover and see if it pans out. I think I'll need to add in a rear camera before I make any attempt as it will be very hard to see behind me once I build up that transition area.
Hopefully I'll be able to Tyvek the lid tomorrow and go fer a quick spin.
03-03-2014, 06:11 PM
#159 (permalink)
T-100 Road Warrior
03-04-2014, 10:14 AM
#160 (permalink)
Great project! I was wondering when someone would start looking into single wheel trailers for this purpose.
I have some experience with this type of trailer, and I wanted to make a suggestion on the ride quality issues you had at first (and I assume still have, although you have moved on).
It is VITAL that the trailer (or more specifically, the wheel pivot) is level. If there is a slope, it can be slightly toward the front (i.e., the front of the trailer slightly lower than the rear), but never ever should the front of the trailer be higher than the rear. The physics of this causes the wheel to try to move to the side rather than line up as it is being towed.
The reason that adding weight helped you get a better tow is that it leveled out the trailer and corrected the physics. That's why there is usually an adjustment on the hitch attachment for the ride height to be able to level the trailer.
Looking forward to your success on this project so I can copy it!
The Following 2 Users Say Thank You to UtopiaCRD For This Useful Post:
