Old 11-11-2014, 03:02 PM   #291 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Rear bulkhead...
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (11-12-2014)
Old 11-11-2014, 07:18 PM   #292 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
A quick shot of the trailer belly pan...almost there!
Old 11-12-2014, 12:07 PM   #293 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
This is my direction fer the trailer belly pan. I know I can't have it this way because when the wheel swivels around when I'm backing up, the tire will crush the belly pan. It's possible to build a hinged cover that moves up when contacted by the wheel and lay flat when traveling forward...
Old 11-12-2014, 03:23 PM   #294 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Gettin even closer to completion...with a pool noodle!
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aardvarcus (11-13-2014), aerohead (11-12-2014)
Old 11-13-2014, 12:09 PM   #295 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
The air bag is alive!
I've got 95PSI in the air bag and 60PSI in the tire. I was able to put my entire body weight (~170lbs) on the back of the trailer and it only squatted about 2".
I was wondering if an air reservoir would make a difference or not.
jeff88 (11-16-2014)
Old 11-13-2014, 01:51 PM   #296 (permalink)
You have a very political trailer!
The Following 2 Users Say Thank You to Xist For This Useful Post:
BamZipPow (11-13-2014), jeff88 (11-16-2014)
Old 11-13-2014, 02:56 PM   #297 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Front side is enclosed. I used FRP on the bottom edge since I'm all out of Coroplast signs.
Access doors are on!
Xist (11-13-2014)
Old 11-13-2014, 03:01 PM   #298 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
I'm thinking of a name fer my trailer...maybe "Dark Shadow" since the original name was The Shadow...and since I should see it at the pumps with the increased MPGs.
Old 11-13-2014, 04:42 PM   #299 (permalink)
air reservoir
*'seems like a reservoir would change the spring rate of the bladder.
*looks like Fastenal came through with the 1/4-to-1/8th adapter!
*And I see the castle nuts that will allow for the wheel pant structure
Old 11-14-2014, 10:53 AM   #300 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
I think I might have my trailer side bottom gap filler solution!
I have one piece of FRP left over from my FRP side skirt experiment and it seems to be the perfect depth to attach to the bottom front of the trailer. It will be reinforced with a 1"x2" frame and will be mounted with two hinges to the bottom edge of the trailer. It will swing up into the horizontal position and git locked into place with some support bars similar to my access doors. The front edge of the gap filler will be about 2" in front of the pivot points of the hitch. I might be able to attach an extra 6-10" piece to the truck's extended diffuser to take care of the remaining gap. The front stabilizer wheels will just clear the top of the cover when the wheels are stored.
Fer storage of the bottom gap cover, it should be able to clear the ground if I let it just dangle in the vertical position. If that doesn't work, I'll probably try either a magnetic attachment or just a clevis pin on one side.
