Old 08-14-2010, 12:43 PM   #1 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Kamming a sedan GrandPrix
Looking at http://ecomodder.com/forum/showthrea...read-9040.html got me thinking about adding a Kammback to my 03 Grand Prix. I think I would be able attach one with double sided adhesive like used to attach rain guards.
The template I'm using is.
Name:	drag shape 1.gif
With adding a kammback/partial kammback I'm not sure what line to use, so I attached this picture to get comments on what to follow.
Name:	all 3 kamm small1.jpg
I figure that I will end the kammback at the line in the window on number two. I think the best option will be #2 or 3 but would like to insight on this be fore I go to work on it.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 08-14-2010, 02:00 PM   #2 (permalink)
photo scale 1st!
Attachment 6583
Attachment 6584
Phantom,first off,you'll either need to enlarge the photo of the Pontiac,or shrink the template image such that the bottom of the tires for car and template 'plane out' at 'ground' level,while the roofs are matched.
After that,what you did with the #2 image seems to capture the maximum roof height and location with the template correctly.
Once your image scale is correct,you're good to go!
Old 08-14-2010, 07:42 PM   #3 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
# 2 looks like the right shape. I that the car will look great with it!
what material are you going to use?
double sided tape holds nicely to colorplast, hot glue works well too.
Old 08-15-2010, 07:19 AM   #4 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Phantom, have you seen Groar's Uglyback? It keeps a sedan's trunk functional, but I'd like to see a hinged extension on that...
Old 08-15-2010, 06:37 PM   #5 (permalink)
Phantom's Avatar
Aero I was using the out side edge to line up I see where the template is not perfect at the bottom but I think that is from the picture not being level. I was mostly using it for a reference and to get opinions on what angle to take it at as I will have to later figure out what real world curve that will be.
I will start with card board and then move to colorplast. Weather thanks for the hot glue tip although I do not know how that would hold up to cold but I might do that for testing. If I get really ambitious I might eventually try to make a fiber glass version but that probably will not happen.
Piwoslaw I have seen the uglyback that is about what I am aiming for function wise.
The Kammback will be more of an upper spoiler and have some of the shading effect of a louver. Some of my requirements are to have a fully accessible trunk, keep 95% of the rear visibility, and keep it looking semi-stock. The last two requirements is why I referenced your thread Piwoslaw.
I guess my next step is to figure out the angle of the rear glass to the angle of the kamm so I can make a triangle to use for setting the final angle. Then start fitting the cardboard to the curve of the glass.
BMW 535i GT fastback has higher Cd than 535i Sedan RobertSmalls Aerodynamics 5 06-18-2010 10:45 AM
Sedan Kammback? KJSatz Aerodynamics 10 09-28-2009 04:58 AM
Metro hatchback vs sedan guitarterry EcoModding Central 12 02-09-2009 04:29 PM
1992 Metro sedan needs a new engine - What/Where/How - advice appreciated greatly! Crono EcoModding Central 26 11-18-2008 01:42 AM
1995+ Metro sedan coefficient of drag: .32 MetroMPG Aerodynamics 1 07-16-2008 10:02 AM
