Old 08-04-2011, 05:39 PM   #1 (permalink)
Laura the Lancer - '81 Mitsibishi lancer LX
WOW - What a difference
Its that time of year to do my maintenance (check timing, set tappets etc..)
TIMING:
stock:8btdc,
maintenance check:10btdc
I run 12 btdc (on 87ron (91 ron in nz) no pinking
tappets:
reset tappets to stock clearances
THE CARB:
jets were rediculously dirty, cleaned them out with carb cleaner,
checked the fuel adjustment screw, HOLY CRAP ITS ALL THE WAY OUT,
A/F ratio was 11.5/1!!!!!!!!!!
(omg and i was still getting 35mpg)
have leaned carb to about 14/1 (have to compensate for driving)
but wow!!!!, i cant believe the a/f ratio was that bad, im glad i do maintenace checks, i have more power and it starts better now as well,
Will have f/e numbers up soon, keep an eye on my graph, hopefully it will go up
Old 08-04-2011, 08:30 PM   #2 (permalink)
...beats walking...
...I'm curious, what instrument did you use to determine the A/F ratio was 11.5:1 (at idle?).
Old 08-04-2011, 09:10 PM   #3 (permalink)
I have a friend that owns a rolling road dyno
every year I use it for maintenance
a/f was done by a teter up the tasilpipe
11.5/1 a/f ratio was actually done at 60kph
(roughly 35mph)
when tested at idle it was roughly 12.7ish
Why do you ask mate
Old 08-04-2011, 10:36 PM   #4 (permalink)
...beats walking...
...because I was wondering *if* a new MPG-meter had been devised that was somehow (?) able to derive or calculate A/F from data extracted from the OBD-II connection.
...I didn't think it was possible--but, I've been wrong LOTS of times--so I asked.
Old 08-05-2011, 08:23 AM   #5 (permalink)
Nice find. I'm sure that tune up will help!
Old 08-05-2011, 11:15 AM   #6 (permalink)
um... my cars 29 years old bro,
i used words like carb, obd2 and carb just doesn't go together, judging by the cars you have im sure you know how to work on the 'old faithfuls
Old 08-07-2011, 10:24 AM   #7 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 49.01 mpg (US)
"Does your car have an OBDII hookup?"
"Yes. It's in the passenger seat. I found it at a junkyard for $5."
That's where I am. Josie's version of OBDII is a flowmaster muffler (Earbone Tech Tacho Systems patent pending), whatever crusty ol' Sears timing light I can hook up to the #1 plug wire, and a notebook.
Old 08-07-2011, 01:33 PM   #8 (permalink)
...beats walking...
...I'll take that response as: "...nope, nothing but old-fashioned tools..."
Old 08-07-2011, 01:57 PM   #9 (permalink)
Smooth Operator
Old Yellar - '79 MGB Tourer Drop-Hood Coupé
Sports Cars
90 day: 25.83 mpg (US)
Old Brown Ford - '91 Ford Bronco Custom
MAGNUM - '05 DODGE MAGNUM SXT
timing
after i put in a new dizzy i set time by ear,, no plink .. did not run very good at low RPM's ,, when i checked it with a light it was at 60 BTDC can you imagine , engine running at 60 BTDC and no ping/plink ..there is an additive jar attached to the intake manifold that i put different *stuff* [var. mixtures of fluids] to which i attribute the no-ping ..
set for 20 BTDC and runs so very much better ,getting quite good FE next time i fuel i get a reading.
here is high tech tools these parts
tried var. methods of setting the mixture ,, engine speed/ vacuum gage ..now trying to set mixture using the EGT[exhaust Gas temp] set for LOP[lean of peak] a AFR would be nice but pricey ,,
Old 08-09-2011, 06:28 AM   #10 (permalink)
sorry mate, didn't mean to offend, yeah when on 95ron (equivelent to 91ronish in america) i set it on 20btdc, but thats costing so i thought i would try the 87ron (91 ron over here), had to retard the timing to what it is now,
my engine doesnt seem to like static timing so I might have a gander at the timing chain and see whats going on, maybe it has stretched
