Old 05-03-2016, 01:22 PM   #1 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Restoring power to an old engine (maybe some economy too)
I stumbled across this last night. They work at restoring power to an old engine. Some of this (like the new plugs and wires) would translate to better economy too. I was also surprised to see the snake oil work so well.
Old 05-03-2016, 02:58 PM   #2 (permalink)
They mentioned testing it eight times and taking the highest figure, did they do that before making any changes, and then after each one? I would not have thought taking the highest figure was scientific, but they were consistent with it, right?
Old 05-04-2016, 02:24 AM   #3 (permalink)
They're not telling us what fuel is in the system. It may also be likely that the cleaner is an octane booster.
Also, they should have done the air filter and oil separately. As far as many of us know, a clean air filter won't do jack for extra power.
Old 05-04-2016, 02:25 AM   #4 (permalink)
But there were leaves in the intake!
Old 05-04-2016, 09:23 AM   #5 (permalink)
DieselMiser
ConnClark's Avatar
If you look up Redex fuel additive it is a detergent and not an octane booster.
Also a clean air filter will increase power on a gasoline engine because it allows more fuel/air mixture into the cylinders.
Old 05-04-2016, 10:02 AM   #6 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
actually, not so much.
there is a study done with a completely clogged air filter. Im just too lazy to search for it
ok, im not THAT lazy!!!!
http://ecomodder.com/forum/showthrea...ter-12590.html
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 05-04-2016, 11:22 AM   #7 (permalink)
DieselMiser
ConnClark's Avatar
For power it does make a difference
"The simulated clogged filter significantly affected vehicle performance, increasing the time to accelerate from 20 to 80 mph by 0.6 to 1.7 seconds on the three vehicles. The Outlet DP measured for each vehicle was sufficient for setting a common air filter indicator to the “change” or “clogged” position. For each vehicle, the Outlet DP at some point exceeded 5 kPa and showed an increase over the clean filter in excess of 2.5 kPa, a common standard for defining a dirty air filter.5,9–11"
Old 05-04-2016, 04:52 PM   #8 (permalink)
Did you see the filter? It did not look very dirty!
Old 05-04-2016, 09:12 PM   #9 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
If you want to restore power to an old engine, pull the intake manifold and clean it and the back of the intake valves. The ability of a dirty air filter to restrict flow pales in comparison to coked up intake valves.
The Following User Says Thank You to ksa8907 For This Useful Post:
Xist (05-05-2016)
Old 05-05-2016, 03:26 PM   #10 (permalink)
DieselMiser
ConnClark's Avatar
Did you see the leaves in the airbox? Leaves don't flow well when pressed up against a filter.
