06-27-2024, 10:59 AM
#1321 (permalink)
Probably more like standard springs weren't enough, we will just do two without adding more leaves qnd making it much stiffer
07-03-2024, 05:06 AM
#1322 (permalink)
Adding all the leaves to one single pack on each side would have more downsides than anything else. But anyway, makes me wonder if, instead of 2 leaf spring packs on each side, auxiliary coil springs like those which used to be offered as an accessory for the Ford Model T.
07-03-2024, 10:19 AM
#1323 (permalink)
Having tried and failed at it, the coil spring add on involved a ton of mods because the pockets for the springs have to be wicked strong and shaped to constrain the spring when compressed
Didn't look like a lot of spare space between the spring and frame so you're going to need a really high rate spring which increases mounting issues.
08-16-2024, 02:17 AM
#1324 (permalink)
08-16-2024, 04:08 AM
#1325 (permalink)
No doggo?
08-22-2024, 02:13 AM
#1326 (permalink)
Originally Posted by redpoint5
No doggo?
Doggo was wrapped around my neck while I took those pictures
09-28-2024, 02:02 AM
#1327 (permalink)
Must confess I would be tempted to get one of these...
09-28-2024, 03:11 AM
#1328 (permalink)
What is it? My guess wold be Subaru BRAT.
..Without freedom of speech we wouldn't know who all the idiots are. -- anonymous poster
..I before E, except after C -- trust the Science
09-28-2024, 10:49 AM
#1329 (permalink)
Tailgate badge says nissan
10-03-2024, 01:17 AM
#1330 (permalink)
That's a Nissan B140, better known in South Africa as Nissan Bakkie. But I spotted this one in Aceguá, Uruguay.
