Old 08-07-2008, 11:55 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
My hairbrained hybrid hidea!
Here's the HHH:
So, I've got two spots open on the crank pulley from not having a/c or power steering. I thought: why not toss a small motor on that could add a few watts to assist the engine? I could get some extra batteries and charge MIMA-like with a button that I flip on during engine braking or what have you (or plug in at home).
Tell me why this is a stupid idea, and I'll forget about it,
Old 08-08-2008, 01:04 AM   #2 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 honda civic Hx
Last 3: 58.02 mpg (US)
I vote fifth wheel though, seems like it would be a little more useful.
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 08-08-2008, 01:07 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
But then rolling resistance and hitting crap in the road and all that come into play, eh?
Old 08-08-2008, 01:13 AM   #4 (permalink)
I've seen such a device mentioned before... was it autoblogreen?
Old 08-08-2008, 01:14 AM   #5 (permalink)
Red
Red's Avatar
Worth a shot
Old 08-08-2008, 01:16 AM   #6 (permalink)
Vince-HX's Avatar
There was one that I saw that was lowered via air cylinder and the tire was a scooter tire so I don't think its a huge RR disadvantage.
A fifth wheel could really help by letting you go EV only and would be great in stop and go traffic and prolonging glides.
A engine mounted motor could help to extend highway leanburn capabilities since it could take some load off the engine. It would also help get to cruising speed a little quicker I guess.
From what Ive seen a nicely sized etek motor with regen kit will cost about $1000. I want to use that setup on my (still on paper) three wheeler.
I think it would work but it seems like quite a bit of time and money.
www.full-race.com
Old 08-08-2008, 01:19 AM   #7 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vince, you kinda hit on what I was thinking: staying in lean burn on the highway, up hills that might otherwise be to big, or what have you. I'm not really looking to spend much money, kinda hoping this is something I can hack together,
Old 08-08-2008, 01:32 AM   #8 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
Does anyone have a photo of a fifth-wheel hybrid setup? I just googled for it and found a modded insight: Is it too late? - MIMA Honda Insight Modified Integrated Motor Assist Tour De Sol
The idea the OP proposed interests me personally more than the fifth wheel gag, but I honestly have no clue which would give more MPG. Would the electric motor use exclusively its own plug-in batteries or would it be connected to the "real" battery also?
Old 08-08-2008, 04:02 AM   #9 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Not a bad idea. Lossy compared to the 5th-wheel setup, but compared to low load operation it's a win-win. IIRC, I think I fiddle around w/ the numbers and figured that w/ lead acid batteries it would be worthwhile w/ gas at $3/gallon even if it only went up to ~10-15mph, just because BSFC at those speeds is crazy high. GM's BAS supposedly increases the efficiency of the Vue by ~20%. If you could fit one, a modded ~3-4hp 36V golf cart motor would be great. You could toss in a ~$600 LiFePO4 pack if everything works out and have something that'd be a half to a quarter of the cost of gasoline to run at low load.
Old 08-08-2008, 05:52 AM   #10 (permalink)
Here we go:
Electrocharger / Retrofit Hybrid :: Sigma Automotive
Are hybrid SUVs a good or bad thing? SVOboy Hybrids 71 05-05-2017 03:24 PM
Camry hybrid selling at record pace SVOboy Hybrids 31 05-27-2012 06:32 PM
Malibu Hybrid bennelson Hybrids 17 12-21-2011 10:57 PM
Sat, May 10, Houston Hybrid and Hypermilers Club Dan. Hypermiling / EcoDriver's Ed 3 05-10-2008 03:19 AM
Click and Clack puzzler: SUV or Hybrid? A Familial, MPG Conundrum! MetroMPG General Efficiency Discussion 0 12-20-2007 01:09 PM
