Old 08-09-2008, 12:14 AM   #11 (permalink)
You're welcome.
Old 08-09-2008, 02:44 AM   #12 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
No Thank You Frank!!!!!
Old 08-09-2008, 09:55 AM   #13 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
Originally Posted by KJSatz View Post
Would the electric motor use exclusively its own plug-in batteries or would it be connected to the "real" battery also?
I'm pretty sure it would have to be separate; otherwise the alternator would try to recharge the batteries, resulting in lower efficiency.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 08-09-2008, 08:37 PM   #14 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 honda civic Hx
Last 3: 58.02 mpg (US)
golf cart for parts
so when can we expect to see a prototype?
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 08-09-2008, 09:43 PM   #15 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Would you use it to re-start also? Seems like a good idea to me. What sort of batt setup are you looking at?
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 08-10-2008, 04:06 PM   #16 (permalink)
Efficiency freak
Bearleener's Avatar
Frugolf - '96 VW Golf wagon
90 day: 40.36 mpg (US)
Have you considered storing the energy as compressed air? An air motor is very compact. Have it pump air into an (LP) gas tank (in the spare tire well?) while braking, then use that compressed air to drive the motor during acceleration. If I calculated correctly, you can store about 100 Joules of energy per litre of tank and atmosphere of pressure. So a 5-gallon tank pumped up to 100 psi has enough energy (13 kJ= 3.6 Wh, ignoring losses) to accelerate a 2400-lb car to about 11 mph. Not too bad, relatively cheap and needs only a very primitive controller. This is sort of a surge regenerative energy concept like they're designing for Formula 1 cars.
I've been looking for places on my car to couple the energy in. The only place I found was the inner CV joint housings on either side of the differential. These are sturdy, 100-mm-diameter cylinders that you could theoretically attach a drive belt or rubber roller to.
You ever notice that birds pulse & glide, too?
Last edited by Bearleener; 08-10-2008 at 04:19 PM.. Reason: corrected units: 3.6 Wh
Old 08-10-2008, 11:18 PM   #17 (permalink)
Ok -- I just signed up and I just found this site -- and wow -- what a bunch of open minded folks -- thank goodness. Ok -- I call this idea a Hybrid Adapter -- or HYBRAD -- as we are adapting to the situation at hand and making a hybrid out of our existing car.
There are a few ongoing projects -- please go to my wiki page which is hosted at the PESWIKI project -- link at http://www.hybrad.com
These HYBRAD efforts are all still on the ground floor as far as I'm concerned -- it is a good time to get in and produce some solid results -- modifying your ICE car and making it a hybrid is not rocket science -- but you have to put some effort into it. I'm building my "fifth wheel" out of a Ninja 250. This other guy built a "pusher trailer" -- see the wiki page.
I'm looking forward to working with you all and really glad I found this place.
Old 08-11-2008, 01:59 AM   #18 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
iHero -
There are a few ongoing projects -- please go to my wiki page which is hosted at the PESWIKI project -- link at HYBRID ADAPTER
Welcome to EM! Sounds like you're working on a ground-up Electric version of these "EV Extender's" :
Mike Chancey's Civic Pusher Trailer
EV Pusher Trailer
Idea: The shape of the trailer could accommodate a tear-drop "boat tail" shape to "complete" the aerodynamics of a car.
CarloSW2
American Solar Energy Society
Old 08-11-2008, 02:08 AM   #19 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
I think that a trailer is a lot more intrusive than a fifth wheel, which is in turn a lot more intrusive than the OP's idea. But perhaps with that intrusiveness comes even greater effectiveness?
Old 08-11-2008, 03:15 AM   #20 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
The trailer can often offer an aero benefit as well. Budget can impede this design tho.
RH77
_
_
Are hybrid SUVs a good or bad thing? SVOboy Hybrids 71 05-05-2017 04:24 PM
Camry hybrid selling at record pace SVOboy Hybrids 31 05-27-2012 07:32 PM
Malibu Hybrid bennelson Hybrids 17 12-21-2011 11:57 PM
Sat, May 10, Houston Hybrid and Hypermilers Club Dan. Hypermiling / EcoDriver's Ed 3 05-10-2008 04:19 AM
Click and Clack puzzler: SUV or Hybrid? A Familial, MPG Conundrum! MetroMPG General Efficiency Discussion 0 12-20-2007 02:09 PM
