Old 08-01-2008, 07:48 PM   #1 (permalink)
Nden's Avatar
Send a message via MSN to Nden Send a message via Yahoo to Nden
Turtle Smog blues....in so cal
btw, the butt-connected 5wire o2 ngk i bought from ebay $60 is not working no matter what i try to requesting refund . also bought a fully intact new L1H1 on ebay from diff seller for $88 I post in seperate thread how that works . my vx failed smog last week (ya i took ages gettin bringing it to a place), across from the chula vista dmv. after going to cheap mexican muffler place(luv their prices) it turned out my 2yr old car-sound?? cat was bad and some of the honeycomb was loose inside making my NOX super high . I had a spare obd2 49state cat welded in (new) and once I get a diff direct connect 5wire wideband o2 sensor I'll go back for retest. Additionally I found a VX throttle body & will be swapping out the JDM Intake manifold (looks like DX/EX sized TB on it) to decrease air-intake. Once I pass then will install the APexi gen1 VAFC meter ala Boomslang harness
VIVA VX !!
If you don't know your rights, its like you don't have any at all. Pre Paid Legal & ID Theft Services Restoration available... check out
http://www.deantaber.com
Old 08-02-2008, 11:56 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Good luck with the retest,
Old 08-04-2008, 02:52 PM   #3 (permalink)
Red Egg - '95 Ford Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Dodge Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
A brand new cat should sneak you through. I would definately take off everything and put it back 100% stock then add the parts back piece by piece keeping an eye on the mileage and if you lose tq in city driving. A tb that is too big causes slight stumbles you may not notice but your computer goes rich/lean extra times and that hurts economy/emissions. I'm in so cal too and want a vx powered honda, so im watching your story on here.
Old 09-19-2008, 08:33 AM   #4 (permalink)
Nden's Avatar
oh snap forgot bout this thread. ya I got new cat on, but not retested yet. still have the bigger IM (jdm D15B) that came with my vtec-E & had an egr on it -weird. LOL i have a us VX IM & TB but my add kicked in weeks ago and i missplaced the butterfly plate from that TB ....to clean it... DX/EX butterfly plate is like 1-2mm bigger diameter so not proper. Additionally, i've tried 2 different new 5wire o2 sensors from egay, one butt-connected which i went to solder but may have crossed 2 wires cuz diff colors from the oem. Also a complete oem 1 that had like a lil resistor between 2 pins on the connector??? just mailed that one back cuz it still set off the CEL even after i reset the ECU 15amp fuse. stay tuned... sigh.
Old 10-25-2008, 03:47 AM   #5 (permalink)
Nden's Avatar
update ... finally got a proper usdm VX intake manifold w/TB and swapped it in , i noticed the jdm 1.5L vtec-E IM looked very similar to the VX except the TB was about the size of a DX or EX Tb. Now to adapt or find a cx/vx air-tube to my EX/oem air filter box. home depot lookout! the VX tb is about 2" diameter so ill need to adapters like a 2-2.5 and a 2.5 to 3" or such. New cat welded in back in July so gettin close to stock. Also put on some new Kumho Solus 185/70/13 tires 70k so that helps along with an adjustable front Upper-A arm camber kit & new bushings for them A-arms.
Old 10-25-2008, 03:55 AM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
My JDM vtec-e intake was an identical size to the usdm one I had.
Old 12-02-2008, 03:38 AM   #7 (permalink)
Nden's Avatar
GOOD NEWS! I passed 2 weeks ago finally after getting an o2 that worked. Additionally, I bought a $330 carb CA approved obd2 OEM header/cat which lowered NOX and rest to very low values (post later). Course the smog tech scratched his head with the D15B jdm stamp...but was ok with the vtec-E valve cover & excellent results from the sniffer. Now to turn in these 2 fix-it-tickets for expired tags .
41mpg my best with mostly freeway driving. I strongly suspect this block is higher comp then the Z1, of which i've seen an imported Z1 besides my vtec-E D15B.
My exhaust from A pipe back is 2" so I shall be going back to the oem 1.75" piping very soon and will be curious if that helps the mpg. Maybe install a crane Hi-6R capacitive ignition i have laying around if i cant trade it for the smaller Hi-6.
Front tires = 13/185/70, rear 14/185/60
fs so cal; set of four vx wheels and old tires getnpsi For Sale 1 09-19-2008 08:34 AM
Hello from So Cal Arkaneinc Introductions 4 07-24-2008 01:14 PM
Anyone want to partially trade your VX or HF for a TDI Beetle? N. Cal aaronp1 For Sale 0 04-28-2008 09:19 PM
