Old 07-31-2008, 04:54 AM   #1 (permalink)
What? THIS IS MY GOOD CAR
justpassntime's Avatar
The Japillac - '87 Honda Accord LXi Sedan
90 day: 31.77 mpg (US)
Ranchero GT - '73 Ford Ranchero GT
Spaz - '83 Chevy S10 4X4 Tahoe
90 day: 27.53 mpg (US)
Send a message via ICQ to justpassntime
Ecommding material...
Was thinking about thin covering materials and thought about the shrink wrap they use for boat storage. It would work really well for boat tails and grill blocks and such.
Honda...the economical, renewable resource.
Old 07-31-2008, 12:30 PM   #2 (permalink)
Ecomodding Dabbler
sohl's Avatar
LilRed - '03 Mazda Protege LX
90 day: 29.09 mpg (US)
I know you brought this up in my aero mods thread where I posted how I used shrinkable window film for a grille block. It worked OK for a short test, but was loosening up every couple of days after a week, so I replaced it with a studier material (from a plastic expanding portfolio).
I'm not sure the type of shrinkable film for boats and such is the same basic stuff used for window insulation kits. If so, my advice is: yes, use it for temporary tests, but don't expect it to last long. If it's thicker and stays taut better than the window stuff, it would be very useful.
Old 07-31-2008, 12:39 PM   #3 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
you can cover a yacht with it and it will hold up snow over a winter. Probaby a good option. I've never seen it clear, though, always white.
Old 07-31-2008, 02:09 PM   #4 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
Is it UV treated? Most plastics without that don't stand up too long to Mr. Sol. I'm using plastic sheets over my fog lights but we'll see how long those last. I think the tape will go before it will.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-31-2008, 02:29 PM   #5 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
That may be true, but a yacht isn't driven at hwy speeds continuously. Even the light aluminum I used in my initial grille block testing ended up denting due to the force of the wind pushing on it. Nothing beats Painters Blue tape for temprorary modding, but always seek the permanent solution.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 08-01-2008, 03:55 AM   #6 (permalink)
Seems this material comes in many different thicknesses up to 12 mil. and has UV inhibitors.
Comes in clear, white and blue.
Redneck Aerodynamic Improvements: Shrink wrap your whole car then spray expandable foam insulation under the wrap. Wait for it to cure, pull the wrap off and carve your car any shape you want.
Expanding, sprayable foam as an aero construction / shaping material MetroMPG Aerodynamics 10 01-18-2013 03:04 AM
Possible source for bellypan material wagonman76 Aerodynamics 1 07-24-2008 04:26 PM
Eye candy...drool material Stan Aerodynamics 7 07-12-2008 03:03 PM
Material for LGB Skroober Aerodynamics 3 06-29-2008 12:35 AM
New material from dupont might cut auto weight significantly SVOboy General Efficiency Discussion 4 02-28-2008 11:23 PM
