Old 07-22-2008, 01:41 PM   #1 (permalink)
SilverStang - '00 Ford Mustang
90 day: 22.23 mpg (US)
What is wrong with my scangauge II?
I was driving and my scangauge II shut off then I pressed the home buton to turn it on, then it was frozen so I unplugged the wire and put it back in and now the symbols for RPM GPH and etc.. all have a square in front of them. Is my scangauge II broken or should I just leave it unplugged for a while. All my trip values and everything are all messed up and it says $6k in fuel and 2.4MPG which I know all of the values and none of them are correct. What do I do?
Finally got my 20% above EPA
Old 07-22-2008, 03:57 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Did it get really hot or anything like that? I'd contact linear logic if it doesn't fix itself.
Old 07-22-2008, 04:18 PM   #3 (permalink)
I don't know it just started shutting off and displaying weird values it does the normal 4 gauges right and real time MPG now but now it tells me tank average and MPG and fuel used are all in like the thousands I don't know what to do?
Old 07-22-2008, 05:06 PM   #4 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
Unplug it, leave it inside somewhere cool.... then plug it back in. If its still all wacky, try resetting everything:
MORE >> MORE >> MORE >> USE DEFAULTS >> YES
If all else fails, call up LL and tell them your troubles.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-22-2008, 10:38 PM   #5 (permalink)
ok everything is still a bit confusing but its only under the today part not under current or tank. the weird values only appear under the today thing not in current or in tank but the odd thing is the scangauge thinks I filled up and I'm only slightly below 1/4Tank of a 15.7Gallon tank is this what caused the problem because it needs to be refilled at 1/4 tank or it will go beserk?
Old 07-22-2008, 10:45 PM   #6 (permalink)
NewBlue - '07 Honda Civic EX
90 day: 38.13 mpg (US)
The Better Half - '97 Ford Ranger XLT
90 day: 25.84 mpg (US)
I am getting some similar strange behavior on the today/previous day type data, I'm thinking it gets confused in hybrid mode and can't figure out when a day truly ends possibly? tank info seems to be pretty good and trip info is usually good so that's what i mostly care about anyway
2007 Honda Civic Ex
Second Goal = 50mpg
First goal = 40mpg Goal Achieved 3 tank average over 40mpg
Starting point 30mpg ready...... GO.
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Official EcoModder ScanGauge II group buy info MetroMPG Instrumentation 71 03-30-2010 07:48 PM
What is X Gauge (on the ScanGauge II)? NeilBlanchard Instrumentation 5 07-22-2008 08:07 PM
just got my SGII (ScanGauge II) few questions for the collective.. Chris D. Instrumentation 27 04-22-2008 07:38 PM
ScanGauge II on eBay (not mine) MetroMPG For Sale 15 02-29-2008 01:44 PM
