Old 02-25-2010, 11:17 PM   #21 (permalink)
Some additional pictures:
aerohead (02-27-2010)
Old 02-26-2010, 07:08 PM   #22 (permalink)
There was talk of making a road going version using the 5 cylinder diesel to replace the 4 rotor rotary of the experimental cars and Mercedes did extensive research and published quite a few papers on the idea.
Other demands meant the project was halted but the 5 cylinder moved to the production line and was used in the W123 series cars initially (1976 to 1985) and other variants later.
There were also scale models made in die cast in 1:18 th scale of the road going prototypes and some were available from MB dealers at the time.
Pete.
The Following User Says Thank You to Peter7307 For This Useful Post:
Old 02-26-2010, 07:45 PM   #23 (permalink)
Is that a pointy nose I see?
Why does it have louvres instead of a smooth rear window though?
Old 02-26-2010, 08:15 PM   #24 (permalink)
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
My guess its to cool the engine that is probably located behind the cockpit?
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
Old 02-26-2010, 10:21 PM   #25 (permalink)
You can see through the louvers (probably) very well. It sure looks like the cooling is in the front.
At the speeds that cars run at, a pointy nose is not required. Look at the Schlörwagen and the Boxfish...
Old 02-27-2010, 12:57 PM   #26 (permalink)
OurInsight - '06 Honda Insight
Phil, bit hard to tell. Was the radiator intake below the stagnation point on the front. I see that the engine compartment was vented to the windwhield "pocket." Looks like a superb setup to minimize radiator drag and windshield stagnation.
Old 02-27-2010, 01:51 PM   #27 (permalink)
looks like
I'm away from home so I don't have my own photos to look at,and I can't remember ( hey at my age I'm authorized now ) but it looks like the area below the lowest slat is open right at the stagnation point,and then they've opened up the area,snagging more air with the additional slats/louvers.
Remember,this was a 'track' car,and operated at W.O.T. for hours/days at the Nardo,Italy track.
Daimler would have been very concerned with engine cooling,operating at the ragged edge for so long.
In day to day operation,the car would never require this amount of cooling air.
At Bonneville,My CRX ran with the temp gauge nearly pegged,so I know this is an issue.
As to the cooling system itself,it is exactly what Walter Korff was pushing in 1963,and it also happens to be what put Wunibald Kamm on the map.The energized flow going over the windshield helped to keep the air from stalling which allowed his roofline to work.
And a safety note: Should a radiator or AC condenser explode ( I've experienced this 3-times ) the hot gases from the cooling system will hit dew-point on your windshield,condense,blind you,and you will in all likelihood crash.The gases from the ruptured AC unit will outright blind you.
It's my opinion that the safety risk of this type of mod overshadows any aero benefit.
Maybe better to move the heat-exchangers rearward as in the Ford concept cars.
Old 03-08-2010, 11:51 PM   #28 (permalink)
93 Metro Streamliner
AeroMetro - '93 Geo Metro
I found another great thread on this car, including press release data directly from Mercedes.
C111-IId and C111-III details from Mercedes
The Following 3 Users Say Thank You to hypermiler01 For This Useful Post:
aerohead (03-09-2010), BamZipPow (03-31-2013), damo (03-22-2010)
Old 03-23-2013, 02:30 PM   #29 (permalink)
pointy
WOW! Sorry I missed this from so very long ago!
Yes,it is a 'pointy' nose.And after revisiting Fachsenfeld's book of 1951 I have a different take on it.
It is the only reference I've seen in which a 'teardrop' was tested 'backwards,' with the pointed end into the airstream.
It's drag is about 29% higher than when going the other direction,but when lowered into ground proximity,and after wheels are added,the drag is less than 15% higher.
The other thing to consider,is that Mercedes-Benz was approaching transonic flow,whereas some parts of the car would be experiencing compressabilty effects and the nose would play a greater role.
What's curious,is that the next year,in 1979,for the C-111 IV,Mercedes shortened and flattened the nose (more like Porsche's 'Flachbau-Schnoz)and then extended the boat-tail almost all the way to 1,500 mm.
Even festooned with all the extra down-force winglets,the C 111 IV measured no higher drag than the III with no wings,but shorter tail,and with extra power pushed above 250 mph for the 1st time.
'Pointy' is okay aerodynamically,but from an automotive standpoint it may not share the architectural caveats allowed the traditional 'teardrop 'forebody,and the necessary windshield angles might render forward vision an optical impossibility.Hucho touches on this aspect of vehicular design.
Old 03-23-2013, 03:05 PM   #30 (permalink)
boat-tail and C-111 III drag pictorial
I have taken a table from Hucho and created three images of the C-111 III with :zero,partial,and full boat tail,and their corresponding drag coefficients.
Mercedes modded C-class: Cd 0.25. Up 7.5 mpg over regular model (with other mods). MetroMPG Aerodynamics 25 04-08-2013 04:57 PM
