Old 11-18-2011, 11:54 PM   #101 (permalink)
Isuzu Imark 1987-89
Chevy Spectrum 1987-89
Cd = 0.38
H = 52
W = 63.6
FA = 18.60
CdA = 7.07
The Following User Says Thank You to Interlocutionist For This Useful Post:
aerohead (08-06-2016)
Old 11-23-2011, 12:12 AM   #102 (permalink)
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
I noticed the Ford Focus wasn't on the list.
The figures for the 2000 MY aka the First generation were well reported. Ford advertised them as:
Sedan:
cD: 0.31
Frontal Area(est): 21.97 sq.ft.
ZX3
cD: 0.36
Wagon:
cD: 0.30
Frontal Area(est): 22.24 sq.ft.
For the "second generation" 2008-2011. The sedan and coupe had the same frontal area and cD.
Second gen Focus 2008+
cD: 0.32
Frontal Area(est): 22.8 sq.ft.
The 3rd generation 2012+ I couldn't find an official cD for a specific model but I calculated the frontal area incase someone finds it.
Sedan/Hatchback:
cD: 0.295
Frontal Area(est): 24.17 sq.ft
Source: The older generations are on Cars.com or any other generic car info site. I got the 2012 cD from Ford media which doesn't specify which body style.
-Allch Chcar
The Following User Says Thank You to Allch Chcar For This Useful Post:
Old 11-23-2011, 12:20 PM   #103 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Ford claims 0.308 Cd for its 1992 Probe. I assume it's the same for the entire generation, 88-92 (1G).
The Following User Says Thank You to Sven7 For This Useful Post:
Old 12-26-2011, 06:45 PM   #104 (permalink)
A Legend in his Own Mind
Ken Fry's Avatar
It's worth noting that there is no standard that manufacturers must use to measure either Cd or frontal area. One rule of thumb, w x h x .81 is incorrect for most cars, (because it does not account for differences in roundness or degree of trapezoidal shape of the greenhouse). Many manufacturers use the actual frontal area of the car and its tires, and do not include any part of the air under the car. Mirrors are often, but not always, included.
In a wind tunnel, Cd cannot be measured directly. It is calculated from drag force (which is measured directly) and frontal area. If two manufacturers happened to make exactly the same car, but one uses mirrors in its frontal area, and the other does not, then the Cd values will be different.
The Prius was measured independently at .30 by a contractor to Chevy (IIRC) when the Volt was being developed. The Toyota number is .25, which I don't doubt. Pretty huge differences for the same car.
Wind tunnels can have either stationary floors or be moving floors, and calculations can be adjusted accordingly (or not). Even when adjusted, the effects are not easily and accurately transferred from one car to another, because the under-car flow effects different cars in different ways.
The Following 3 Users Say Thank You to Ken Fry For This Useful Post:
aerohead (08-06-2016), jime57 (03-17-2012), mikeyjd (03-30-2014)
Old 01-17-2012, 08:48 PM   #105 (permalink)
Eco taco - '21 Toyota Tacoma Sr access cab
90 day: 22.72 mpg (US)
2005 kia rio cD
Old 03-15-2012, 12:09 PM   #106 (permalink)
FFE - '17 Ford Focus Electric
Hyundai Genesis Coupe 2009-2012
Coefficient of drag: 0.32
Frontal area: 2.04 m^2 (or 22 ft^2)
The Following User Says Thank You to jeongyun For This Useful Post:
Old 03-30-2012, 06:02 PM   #107 (permalink)
ZX - '97 Citroen ZX Monaco
OldContinents
90 day: 61.05 mpg (US)
Over 2000 vehicles in xls, not sure if mentioned already, has also other aerostuff, mostly in french:
http://pierreg.grappin.free.fr/MRT/Aero.xls
The Following 2 Users Say Thank You to jtbo For This Useful Post:
aerohead (08-06-2016), jeongyun (03-31-2012)
Old 07-05-2012, 05:26 PM   #108 (permalink)
Sven7's Avatar
Just a small correction to avoid confusion. Although mirrors can raise a car's drag coefficient (Cd), simply omitting them from the frontal area number will not change this measure. Changing frontal area will, however, affect CdA, which is the drag coefficient multiplied by the frontal area.
Removing the mirrors from the car will change CdA and may change Cd, depending on how aerodynamic the mirrors are.
That is all!
aerohead (12-09-2021)
Old 07-10-2012, 11:13 PM   #109 (permalink)
Ezcape - '15 Ford Escape Titanium
90 day: 20.22 mpg (US)
good list
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
https://ecomodder.com/forum/em-fuel-...ehicleid=10608
The Following User Says Thank You to guudasitgets For This Useful Post:
Old 12-24-2012, 06:34 PM   #110 (permalink)
Sven7's Avatar
1980 Mercury Capri (Fox body), via sales brochure
0.48 Cd w/o rear deck spoiler
0.47 with rear deck spoiler
Curb weight- 2548 lbs.
4 speed manual transmission ratios
1st- 3.98:1
2nd- 2.14:1
3rd- 1.42:1
4th- 1.00:1
cda list
List of Low Rolling Resistance Tires Daox EcoModding Central 57 05-13-2019 01:17 AM
What are your 2008 mod goals / wish list? MetroMPG EcoModding Central 45 01-02-2009 01:57 AM
