Old 10-02-2008, 06:50 PM   #11 (permalink)
CAUTION: May Stink!!!
BlackDeuceCoupe's Avatar
BDC's Honda CiViC HX/Si - '98 Honda CiViC HX/Si (HX Shell/Si Swap)
90 day: 40.56 mpg (US)
Send a message via ICQ to BlackDeuceCoupe Send a message via AIM to BlackDeuceCoupe Send a message via MSN to BlackDeuceCoupe Send a message via Yahoo to BlackDeuceCoupe
I see...
Do you ever fill your tank and reconcile it to your odometer/trip meter - or strictly go by your SG?
.:: B16A2 HX/Si Coupe | '98 HX shell with full '99 CiViC Si swap | 40+ MPG
Listen to the people who fail. They know what they're talking about!
Old 10-02-2008, 06:58 PM   #12 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
I never rely on the scangauge .. I always go by my mileage. Which lately has been about 1mpg off from the scangauge.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 10-02-2008, 07:06 PM   #13 (permalink)
It doesn't sound to me like you're cheating - you're just compensating...
It's like, I'll race someone - feel remorseful - and drive like a Granny for a few days.
Old 10-02-2008, 09:57 PM   #14 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
It is one of those "this might be to good to be true" kind of things. I don't blame you for being suspicious. There are many possible sources of error
http://ecomodder.com/forum/showthrea...html#post53360
Old 10-03-2008, 10:50 AM   #15 (permalink)
With my underpowered civic,
I originally tried the slow route,
holding up traffic the climbing hills.
The results were good, but not as good as when I found that at 60 to 65 the results were better.
At the higher speeds, I can coast or DWL better at the higher speeds as I go over the 20% of my commute on some slow rolling hills.
The tall hills still get me back to DWL at lower speeds but once at the top it's better with higher speeds.
The only guess I can come up with is the anemic engine really has to work to get going but once it rolls the aero is quite good.
Old 10-03-2008, 11:27 AM   #16 (permalink)
I'd drive one way and try it for an entire tank to make sure. The SG is probably right, even though it does seem odd. However, I'd double check it.
Old 10-03-2008, 02:44 PM   #17 (permalink)
I'll try it with the next tank, it should make for an exiting test. This tank will continue with 55mph.
