Old 11-01-2008, 07:10 PM   #11 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 52.92 mpg (US)
Originally Posted by cfg83 View Post
JQmile -
Welcome to EM! Sounds like you have a unique classic Chevette there. I just wiki-ed your car and it looks like an Isuzu powerplant :
Chevrolet Chevette - Wikipedia, the free encyclopedia
CarloSW2
It oughta be an Isuzu engine - it was an Isuzu car. The Chevette, maligned little ratmobile that it was, would get you from A to B dry and usually faster than walking, so whatever bad that can be said against it, it had that on the plus side.
I wouldn't turn my nose up at it - if there were any still alive around here, it could probably be bought for pocket change. But all other factors being equal, I think I'd probably insist on the diesel - if I'm going to be seen in a Chevette, I'd like to have a little something to brag about, you know?
Old 11-02-2008, 11:25 AM   #12 (permalink)
Thanks for the welcomes guys. Yeah the engine is a 1.8L, and it spins all the way to 5000rpm, pretty high for a diesel! It also makes 70 lb-ft of torque at 2000 rpm so the car is super easy to drive. I guess my inital goal is to break 60mpg, although I could never do it on any type of daily average: too much traffic here in Los Angeles. I average about 18mph on my commute to work, and my mileage drops down into the high 30s =(.
1989 Dodge Diesel 972rwhp, 27mpg.
1971 Nova tubbed, solid cam 355 w/nitrous, 8mpg (sorry).
1960 Nash DIY Hybrid Project
Old 10-26-2011, 08:47 AM   #13 (permalink)
As soon as I read that article in the diesel mag my quest to find one began. Took me well over a year to source 1 in Michigan. I too was finally plagued with tranny issues this summer. But I just bought another runner driver with a spare tranny from down south and it should be delivered Friday. Now ill have 2 of these bad boys to keep the miles off my Duramax. Muhahaha....
Old 10-04-2022, 12:39 AM   #14 (permalink)
The Isuzu 4FB1 engine is quite underrated, yet it's as good as or eventually better than a Volkswagen engine of the same era. IIRC it had also been used on some export-bound versions of the Brazilian equivalent to the Chevrolet Cavalier. There was also the 4FC1 which BTW shares the same bore and stroke of the current straight-6 turbodiesel fitted to the Chevrolet and GMC half-ton trucks.
Old 10-04-2022, 11:59 AM   #15 (permalink)
Passat TDI Wagon - '97 VW Passat Wagon TDI
90 day: 54.04 mpg (US)
Blue - '21 Hyundai Sonata Blue
90 day: 49.41 mpg (US)
Ford Tempo also had a diesel option in '84 - '86. I have seen one, but have no idea of what gas mileage it could get. It used a Mazda 2.0 L diesel motor.
Wikipedia says the Tempo had a drag coefficient of 0.36 for two door and 0.37 for four door, so it should have been able to get 50 mpg.
97 Passat TDI Wagon
Bosio 520 DLC nozzles, chip tune
Mufflerectomy
306k miles
Scan Gauge II
full belly pan
26 gallon tank
Old 10-08-2022, 03:17 AM   #16 (permalink)
That was the RF engine. Odd enough, this engine and the gasser FE had the same bore and stroke of the 2.0L versions of the GM/Opel Family II engine, but they're unrelated.
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
Mopar to offer Diesel Swap kit for Wranglers Red EcoModding Central 8 08-09-2011 06:23 PM
[FS] 1987 Ford Escort 2.0 DIESEL Drivetrain 5spd Trans SE PA + EXP Project Car XFi For Sale 0 09-30-2008 02:37 PM
As I Had Thought Big Dave General Efficiency Discussion 54 09-02-2008 11:00 PM
i-dtec (Honda Diesel) RH77 EcoModding Central 22 02-11-2008 01:20 PM
