Old 03-21-2010, 04:54 AM   #11 (permalink)
recession proof rebel
k.civic.f4i's Avatar
yea i was reffering to the different body harness hondork was talking about.
the vx transmission swap sounds like a really good idea, cost effective too. has anyone ever done it to their dx or si? would it just be a straight swap? theoretically it should work since it's still onto a d-series engine. theoretical stuff doesnt always work in practice though. i just want to know what works and what doesnt before i start dumping money on stuff. thanks BROS.
how to.....
http://ecomodder.com/forum/showthrea...cks-11998.html
http://ecomodder.com/forum/showthrea...how-12301.html
true wealth comes from good health and wise ways
Old 03-21-2010, 10:08 AM   #12 (permalink)
VX/CX trans is direct fit. Gear correction factors will be off in the ecu, but you shouldn't notice any adverse effects
Old 03-21-2010, 10:47 PM   #13 (permalink)
tim3058's Avatar
Silver Bullet - '86 Chevy Camaro Z28
90 day: 19.74 mpg (US)
New Blue - '96 Chevrolet Camaro Z28
90 day: 20.46 mpg (US)
Diesel - '96 Chevrolet Tahoe LS
Last 3: 13.56 mpg (US)
Tahoe #2 - '95 Chevrolet Tahoe LS
90 day: 13.05 mpg (US)
SuperDuty - '08 Ford F-350 dually Lariat
90 day: 9.34 mpg (US)
Fundai - '09 Hyundai Elantra
90 day: 26.45 mpg (US)
HRV - '17 Honda HRV LX
90 day: 31.39 mpg (US)
Yep, trannys swap no problems... all the same connections and externals. Could have the trans swapped in a weekend ez.
Old 03-22-2010, 04:28 AM   #14 (permalink)
what exactly do you mean by that? sorry im not as mechanically knowledgeable as id like to be
how to.....
Old 03-22-2010, 05:15 AM   #15 (permalink)
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
"gear correction factor" I think he meant the speedometer might be off a bit. no big deal.
When looking for a VX, make sure that is really what you are getting. The VX is the easiest so swap in speed oriented vtec motors. This was a very desirable thing before the kids moved on the K series swaps.
If you are not mechanically inclined as you say, don't even think of doing a engine swap. Have the transmission swapped over and focus more on aeromods, etc.
Old 03-22-2010, 06:56 AM   #16 (permalink)
well not completely mechanically clueless. ive done a d15b into my cousins ex before but it was a straight drop in and plug though. the mechanical part is easy. its the electrical that im concerned with, harness(if it shared the same harness as the ex and si i wouldn't be concerned) and stuff you know?
im going to pick up the transmission and other misc. parts to do the swap on tuesday. its hard to find all the stuff for the swap like the egr box thing and the harness. i think im just gonna do the tranny swap for now until i can collect all the right parts to do it properly.
buying one would be so much easier but i think the swap is do-able(and cheaper).
how to.....
Old 03-22-2010, 12:54 PM   #17 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
For super details on the actual swap, take a look at my writeup here: crxMPG - Gas mileage never looked so good CRX D15Z1 (Civic VX) Fuel Economy Swap Guide
But basically, it's like a normal swap except you'll be adding some plugs for the o2 sensor, vtec, etc.
Old 03-22-2010, 12:56 PM   #18 (permalink)
Dartmouth 2010
SVOboy's Avatar
Also, if you're talking about putting the hydraulic CX/VX transmission into the 88-91 body, you're going to have nothing but pain and trouble with it. I'd advise against. Just get an HF transmission.
Old 03-22-2010, 05:02 PM   #19 (permalink)
The ecu knows what gear the transmission is in and makes timing/fueling (either or both, forget which) adjustments accordingly, but I probably shouldn't have mentioned it.
Old 03-23-2010, 07:53 AM   #20 (permalink)
thanks svoboy. the original plan was to do this swap into a crx shell but i figure.... i already have a dx hatchback and i like seating 5 passengers. so are you running the hf instead of the vx tranny? good job on your insight btw.
greasemonkee, i just learned that you did this swap to basjoos car. he said that you've done it numerous times so..... do you mind if i get your number in a PM to clarify a few things regarding the swap?
how to.....
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 83 06-20-2015 11:30 AM
1992 Honda Civic VX for sale. Boston MA. Stock, factory AC, VX rims, new tires brakes civicvx For Sale 9 12-02-2011 09:47 PM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 02:52 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Looking at buying a civic vx. FE question yoshimitsuspeed General Efficiency Discussion 2 07-23-2008 06:50 PM
