Old 10-11-2008, 01:52 AM   #1 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Disable downshift on my Previa.? Help me P&G!
Four speed auto transmission downshifts way too easily. Does anyone know how to retard it or disable it temporarily so I can pulse and glide properly? It has overdrive too so it should be a pretty good improvement if I can get it to work.
Thanks.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 10-11-2008, 02:51 AM   #2 (permalink)
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
loosen the shift cable connected to the throttle body. i did it on mt lexus es300, that way it takes more pedel to make it down shift.
Old 10-11-2008, 02:50 PM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
RH77 did something similar with the linkage on his Acura. Seemed to work for him.
Old 10-11-2008, 06:20 PM   #4 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
Thanks!
That is so darn simple.
Thanks guys.
Super handy on my previa is access to the throttle body under the driver's seat. I just installed a vac gauge so that cable loosening is the next 5 minute mod.
Sweeeet!
Old 10-11-2008, 10:14 PM   #5 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
Still downshifting too easily
I loosened the cable 1/4 " but it still downshifts too easily. I only tried it at between 50 and 60 kmh though.
I'll loosen it all the way then see.
I'm betting it's a vacuum thing. Bleeder valve?
Help me disable my daytime running lights for more fuel efficiency.... blackjackel EcoModding Central 7 07-27-2008 10:27 PM
