Old 01-13-2021, 08:35 PM   #21 (permalink)
90 day: 39.99 mpg (US)
The second batch I roasted ~6 minutes (I know it's not going to be comparable from machine to machine) and visually looked somewhere a bit past a FC+, but did not taste that way.
The third I pulled off at 5 minutes, and while it looked like a FC, my grinder struggled a bit to grind it (I used to have a Rocky but sold it along with my espresso gear a few years back). It tasted much lighter than a FC, however.
This time around I decided to try my IR thermometer. I'm seeing around ~410° at the 5 minute mark, and ~420-430° at the 6 minute mark, with 3 ounces of a Guatemalan.
So maybe the color isn't too far off. I'm guessing the beans are probably a bit dark to start with because they're older. Shouldn't take me too long to go through 4lbs at this rate though.
A brief clip for anyone curious. Just put the beans in, stir for a few seconds, then wait:
Old 01-14-2021, 10:44 AM   #22 (permalink)
The issue I have with timing roasts: time is dependent on input temperature.
I roast outside and yesterday was 30 degrees so it took 15 minutes to get to FC (406 degrees) At 70 degrees it takes 6 minutes to get there and !SURPRISE! It wasn't linear. The upside: @ 30 degrees there is virtually no after cooking, the beans go cold really fast so roast temp looks like internal temp after a moment in the cooling pan. Hmm maybe I should get an IR temp device if I can believe you look at bean temp instead of air flow temp.
Does your roast guide have temperature addendums like the download @sweet Maria's? I think color is too imprecise but possibly because of my color blindness. I cant see any change until about 390 degrees when the beans start turning brown
Ecky (01-14-2021)
Old 01-14-2021, 10:56 AM   #23 (permalink)
The guide included didn't have a temperature reference.
Old 01-14-2021, 11:05 AM   #24 (permalink)
I found There are several. Here's the easiest "https://library.sweetmarias.com/how-...our-own-coffee
Ecky (01-14-2021)
Old 01-15-2021, 06:19 AM   #25 (permalink)
IamIan's Avatar
Do you have house plants ?
Do you want even more control over your coffee ?
You could buy a sapling already started .. or .. You can plant a few green coffee beans (which is the seed of the plant) to try and get them to sprout. Once started it will take a few years before a sapling matures enough to bear fruit.
I have a dwarf coffee tree as a house plant .. it would no doubt do better in some outside hawaii like climate , but here in RI it does grow and give 30-40 coffee cherries (2 beans inside each cherry) each year.
The tiny coffee flowers that come just before the cherries are also a nice cute touch. Only a very light (barely detectable to my nose) fragrance.
MIGardener has some good / helpful youtube videos about it.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
The Following User Says Thank You to IamIan For This Useful Post:
Ecky (01-15-2021)
Old 01-15-2021, 10:15 AM   #26 (permalink)
Nice but I go through about 52 lbs a year so looking like I need my 1/4 acre backyard full of mature trees in a greenhouse that's temp controlled to get erratic yeilds and flavor profiles
Old 01-15-2021, 07:01 PM   #27 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Gardeners are optimists.
Transmission type Efficiency
Old 01-16-2021, 09:38 AM   #28 (permalink)
And the ultimate optimist is an 80 year old that plants an oak tree for his hammock support.
Fat Charlie (01-16-2021)
Old 01-17-2021, 08:07 AM   #29 (permalink)
IamIan's Avatar
That's one option.
Another option .. if you want to grown your own coffee in your back yard .. in a colder climate than conventional coffee trees will tolerate .. Acorn Coffee
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Mature Oak trees don't need the green house .. and they produce prodigious amounts of acorns.
Old 01-17-2021, 09:14 AM   #30 (permalink)
Originally Posted by IamIan View Post
That's one option.
I'd never heard of such a thing.
Where I live, I have several hundred mature sugar maples on my 1.x acre property, and I have to say, tree sap is also rather nice.
It isn't coffee, however.
