Old 06-25-2021, 06:17 PM   #601 (permalink)
blending
Originally Posted by tomi_k View Post
Something like this... but will need to check how contours of the truck goes and do some estimations of how much "curvature" could be....
Blending all surfaces nicely to the back of the bed (not increasing wake area) and keep transitions of surfaces following closely to the truck's overall shape is the target.... Once that is established, then tweaking surfaces here and there is much easier... taking baby steps while learning....
https://ecomodder.com/forum/member-t...-211524-02.jpg
Yes, Morelli admonished:
* body shape must vary slowly
* body area must vary slowly
* body contour must vary slowly
* body must be as rounded as possible
* body pressure gradients must be as low as possible
tomi_k (06-25-2021)
Old 06-25-2021, 06:37 PM   #602 (permalink)
Unfortunately, some of these rules are deceptive or incorrect. Looking at any low drag current car quickly shows that.
For example, the 'body must be as rounded as possible' applies only in parts - at the rear of the car, we want clean separation and so rounded trailing edges will substantially increase drag. That's why low-drag cars have rear separation edges.
The same for 'body shape must vary slowly' - again, only in certain parts. As shown earlier, to reduce the strength of trailing vortex formation off rear slanted pillars, body shape often changes fast enough to have distinct edges.
It's not a good idea to apply rules of thumb to car modification. There are always exceptions, and as this list has shown, sometimes those exceptions are quite major.
The Following 2 Users Say Thank You to JulianEdgar For This Useful Post:
Bicycle Bob (07-04-2021), tomi_k (06-25-2021)
Old 07-04-2021, 02:35 PM   #603 (permalink)
Leftover wood strips, glue gun and crafting cardboard to make shape templates...
ID:	30970   Click image for larger version
ID:	30971   Click image for larger version
The Following User Says Thank You to tomi_k For This Useful Post:
aerohead (07-07-2021)
Old 07-04-2021, 02:43 PM   #604 (permalink)
Roof and sidewall profiles (front / rear view)...
Old 07-07-2021, 09:51 PM   #605 (permalink)
Framing for basic plywood shape (under final outer shape)... Top braces will be replaced with curved beams and two other beams (between top and side wall) are not visible yet...
The Following 2 Users Say Thank You to tomi_k For This Useful Post:
aerohead (07-09-2021), samwichse (10-08-2021)
Old 07-08-2021, 10:39 AM   #606 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Looking good.
Old 10-05-2021, 01:27 PM   #607 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
https://www.mivehiclesolutions.com/aero-x-cap
Does anyone besides the above sell a commercial aero cap?
What ever happened to Bondo?
The Following User Says Thank You to rmay635703 For This Useful Post:
aerohead (10-06-2021)
Old 10-06-2021, 10:52 AM   #608 (permalink)
Bondo
FoMoCo was impressed enough, that they paid for the wind tunnel testing. But Brett's 'good deed' was summarily punished in the marketplace.
At great personal expense, he gave us a 'CYBERTRUCK' and an offramp out of climate change, a decade before Tesla. Less than a handful of Americans, out of 320-million, recognized the achievement and were willing to invest in the 'capitalist' product. SEMA parachutes for trucks sold well though.
R.I.P. home economics. Arithmetic remains D.O.A. in America.
tomi_k (10-23-2021)
Old 10-23-2021, 03:59 PM   #609 (permalink)
Few progress pics....
https://ecomodder.com/forum/member-t...-191252-01.jpg
https://ecomodder.com/forum/member-t...-121523-01.jpg
https://ecomodder.com/forum/member-t...-204235-01.jpg
Old 10-23-2021, 04:58 PM   #610 (permalink)
If you use rather than , you get this:
Did you drive it and then lift it of without disturbing the yarn tufts?
tomi_k (10-23-2021)
Easy Aero Fix? (Modding a pickup?) DifferentPointofView Aerodynamics 53 04-13-2012 05:46 PM
SAE report: Pickup Truck tailgate aerodynamics... better up, down, or off? MetroMPG Aerodynamics 5 11-17-2011 02:35 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
How much do y'all pay for trash pickup? roflwaffle Saving@Home 15 08-23-2009 10:46 AM
Daihatsu Mira aerodynamic modifications newtonsfirstlaw Aerodynamics 5 06-13-2009 09:43 PM
