Old 08-18-2012, 09:18 PM   #1 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Kia soul kill swich help
I am planning on helping a relative mod is Kia soul to add a kill switch for it.
I found the Fuel injector fuse in the block but its a short min blade fuse and I cannot find a fuse with leads for it. I want to add a NC relay and run a switch into the cab for manual activation as desired.
Any ideas on how to get the fuse terminals into wire leads?
I also can put a relay inline right at the fuel injectors but I would have to do a relay for each one. I prefer to keep the engine bay wires intact if i can.
Here is a diagram I found on the web. If i do the fuse block its killing the bold "2" fuse:
Ideas?
Old 08-19-2012, 06:47 AM   #2 (permalink)
Wiki Mod
I was also thinking about rigging each cylinder's injector to a relay so that I could independently deactivate cylinders, say at highway cruising speed kill off cylinders 2 & 4 in the firing order.
ideas?
Old 08-19-2012, 07:31 AM   #3 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Might be able to just use some blade connectors. Attach the wires to the blade connectors then epoxy the connectors to a suitable backing material to keep them spaced to fit the fuse block. Or maybe try cutting the top off the fuse and soldering wire to the blades I'm sure the fuse part will open from the heat.
The Following User Says Thank You to nemo For This Useful Post:
Weather Spotter (08-19-2012)
Old 08-19-2012, 07:43 AM   #4 (permalink)
Wiki Mod
I like the idea of using epoxy to hold the blades at the right distance apart
Old 08-19-2012, 11:27 AM   #5 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
Wire the switch in just before the fuse panel.
Save gas
Old 08-19-2012, 01:57 PM   #6 (permalink)
Wiki Mod
I cannot get to the wires easily before the panel.
I got some parts today, I bought a tap for the min fuses and will soder on some leads. I will add an inline fuse then I can put my relay in. The auto parts store did not carry a SPDT (single poll, duel through) relay by that name so we had to look through a few boxes to find one that would work.
I think I can then just snake a wire pair into the cab for the switch and be fine. this would give me control over the injector power leads. I will see if I can take a few pics as I go.
Old 08-19-2012, 05:29 PM   #7 (permalink)
Wiki Mod
here is an update:
I wired up the switch and we got it mounted
in the engine bay fuse box:
In the car:
Old 09-11-2012, 03:47 AM   #8 (permalink)
Got soul?
Soulster's Avatar
Soulster - '10 Kia Soul Plus
90 day: 35.36 mpg (US)
100k POS - '01 Dodge Neon
Ohhhhh yeah!
Since my brother installed the kill switch.... 44mpg tank and I just pulled my record high 70.8mpg trip average! Take that EPA average ;p
Old 10-08-2012, 02:56 PM   #9 (permalink)
Are you getting that by turning off cylinders 2 & 4 on the highway or by using the kill switch when stopped or coasting?
Thanks in advance if you respond.
Edit: also, how are you measuring that mpg?
Old 10-08-2012, 03:09 PM   #10 (permalink)
Wiki Mod
I hooked it up so all of the cylinders are killed at once. So it's a "normal" kill switch .
