Old 05-29-2009, 12:04 AM   #1 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 31.12 mpg (US)
Do you smell a scam?
If you have ever looked up getting better MPG I'm sure you have seen these things, do you think they are a scam? Supposedly you stick them in your intake & they spin the air & that will for some reason give you better MPG. Some of the testimonies on these things report +1MPG, +4 MPG, +40% MPG exc. I think its bull, but for $30 it would be worth it if they did work...
ID:	3590   Click image for larger version
ID:	3591   Click image for larger version
ID:	3592   Click image for larger version
Old 05-29-2009, 12:56 AM   #2 (permalink)
Typing "tornado" into the search box might be enlightening
Old 05-29-2009, 01:11 AM   #3 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
A block of wood under the gas pedal would give about the same results - permanent restriction. If you want that, the extra mixing from this rig might be worth a couple of bucks in improved mileage.
Old 05-29-2009, 01:54 AM   #4 (permalink)
Bob- extra mixing? improved mileage? Seriously???
Old 05-29-2009, 02:10 AM   #5 (permalink)
Smokey Yunick was a strong proponent of aids to evaporation of the fuel, so this gadget might help that way. Especially if it was downstream from a dirty injector. However, I wouldn't take the time to install one even if my dad gave it to me.
Old 05-29-2009, 05:13 AM   #6 (permalink)
That is true. His was basically a turbo wasn't it? With no intercooler and running real hot?
If I'm not mistaken these tornados and whatnot install AHEAD of the throttle body and ahead of any fuel. The throttle plate will mess up whatever it is they are purported to do anyway.
Old 05-29-2009, 05:19 AM   #7 (permalink)
Yeah, Smokey's intake temp was getting up to 450 F, AFAIR. No carb icing on his rig. :-)
Gosh, the old J.C. Whitney "turbo" spinners were supposed to go between the carb and manifold. Maybe the suckers are even dumber now.
Old 05-29-2009, 08:15 AM   #8 (permalink)
Tornado Air Management Systems :: Measurement Guide
Yup- ahead of everything.
Old 05-29-2009, 08:19 AM   #9 (permalink)
Send a message via MSN to markweatherill
My question would be: clockwise or anti-clockwise, which is better?
Old 05-29-2009, 08:44 AM   #10 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Put any one of these gadgets in Google and look 2 or 3 pages in.
You will find lawsuits and false advertising litigation abounds.
All of these type of "Fuel Atomizers" have been tested by the EPA and found to do nothing at best and waste fuel while restricting your air flow at worst.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
increase, intake, money, mpg, scam
The Ethanol Scam: Are ethanol advocates giving slanted mpg numbers? Ptero Fossil Fuel Free 15 04-22-2010 09:58 AM
Ethos FR Snake Oil Or The Real Deal? Greenblazer General Efficiency Discussion 21 09-26-2008 04:36 PM
Home Depot Scam!!! ajax_6531 The Lounge 16 07-05-2008 05:34 PM
Newbee with hydrogen kit mechanic999 EcoModding Central 20 05-27-2008 02:17 AM
Scam or not?? Taco Bowl EcoModding Central 3 04-29-2008 11:48 PM
