Old 07-02-2011, 06:06 PM   #1 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
cooling the front brakes
I follow the smooth disc on the front wheels thread.....here.....
http://ecomodder.com/forum/showthrea...tml#post248112
........and one of the concerns is lack of air flowing over the front brakes and reducing the effecency of the brakes.
On the Infiniti Q45 forum I posted the following. I think that the method can be used on this forum also. Several models, Mustangs, BMW 3 & 5 Series have aftermarket kits that do the same thing. THese kits run $1-400 dollars.
I made mine for much less.
1. Need to have an opening in the lower grille that air can pass thru.
A munbered sequence:
2. Parts are available at any hardware store.
Here are the pics:
The plastic wheel well piece will need to be cut to accept a grill.
this is a picture of the passenger side wheel well looking at it from the tire.
the grille is already installed:
here is the part #5 at Home depot:
I cut it in half and used the ohter half on the driver side wheel well.
(painted flat black)
used glue, then tape to seal it.
Here is driver side. Grille #5 is hanging done so you can see #4 opening
This next part #4 is on the inside of the wheel well. The Screen part wedges into this part and provides so 'hold'
here is a pic of the inside with the part #4 installed:
Here is a picture of the inside of the lower front bumper. This is where the air is coming in.
driver side
passenger side
I found part#2 at the hardware store that fits almost perfectly:
Here is the part #2 installed. I used dry flex exhaust hose to attach the two pieces.
driver side
passenger side:
THere are different shapes and sizes in this stuff at the hardware store. I found stuff in drainage, and air conditioning.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 07-02-2011, 06:14 PM   #2 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
I've been running pizza pan wheel covers (front and back) for several thousand miles, including a fully loaded trip through the Rocky Mtns. Never once experienced any brake fading.
Personally, I think the concerns regarding brake overheating with wheel covers are misplaced.
But your project shows ingenuity and MacGuyver-ness that I love!
-Terry
The Following 4 Users Say Thank You to Tango Charlie For This Useful Post:
brucey (07-04-2011), Daox (07-22-2011), mcrews (07-02-2011), NeilBlanchard (07-24-2011)
Old 07-02-2011, 06:19 PM   #3 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
I'm thinking that setup may be overkill. But definitely proof of concept. I would go for something smaller, maybe 1 1/2" diameter. Would you be able to get a few pics from a little farther away? it's hard to get a good perspective of how everything is arranged (for me at least)
Old 07-02-2011, 06:26 PM   #4 (permalink)
mcrews's Avatar
Give me a couple of days. It's all buttoned up.
And yes, the size is what it is because thaose were the parts that fit!
Most bumpers will not have opening that are that large.
Most of the 'aftermarket kits' that I referred to are not bigger than 2"
If I had the factory bumper, the openings are smaller and I would have used smaller parts that fit.
My goal was to NOT have to do too much fabrication.
ECO MODS PERFORMED:
First: ScangaugeII
Old 07-02-2011, 06:28 PM   #5 (permalink)
I had a feeling there was a reason for the size.
Old 07-02-2011, 06:31 PM   #6 (permalink)
mcrews's Avatar
Terry, thanks for the comments.
On the 02-06 Infiniti Q45 forum, some guys complain that the brakes are crap. Given the V8, 340hp and 0-6 in 5.9, the temptation to go WOT is hard to resist for some.
In the 240,000 miles, I have yet to have any problem with the rotors warping or the brakes heating up.
But it was such a slick little project, especially after I found these rectangle ducts that fir perfictly!!!!
ECO MODS PERFORMED:
First: ScangaugeII
Old 07-03-2011, 08:09 AM   #7 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Very nice install.
What goes for brake problems, you can kill almost any cars brakes on tarmac if you have the balls to floor it enough. On normal driver there will be no brake fading issues, even with smooth hubcaps on place.
My estimation is that those ducts will hurt your FE numbers :/. But they will definedly give mind peace on your brakes if you like to play around with your car sometimes on the track etc.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 07-03-2011, 04:29 PM   #8 (permalink)
mcrews's Avatar
Originally Posted by Vekke View Post
Very nice install.
.My estimation is that those ducts will hurt your FE numbers :/. But they will definedly give mind peace on your brakes if you like to play around with your car sometimes on the track etc.
actually, I've had these lower ducts open for about the last yr. My current trip to texas (1500 miles) achieved 30.4mpg which was my best over a long trip.
http://ecomodder.com/forum/showthrea...ast-16970.html
the trade off would be sooooo smalll
ECO MODS PERFORMED:
First: ScangaugeII
Old 07-04-2011, 01:35 PM   #9 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
mcrews, I like it! Good work. I am looking to do the same thing so I don't have to worry about braking with a trailer in tow.
Old 07-04-2011, 05:01 PM   #10 (permalink)
mcrews's Avatar
Joenavy,
I number the sequence and parts and added a few pics.
ECO MODS PERFORMED:
First: ScangaugeII
