Old 01-30-2022, 11:41 AM   #1 (permalink)
A New Internal Combustion Engine Allegedly Produces Nearly Zero Harmful Emissions
only 35 lb (16 kg) and produces an output of 160 horsepower 170 pound-feet of torque.
https://www.motor1.com/news/563664/n...engine-design/
That doesn't sound possible. A Civic engine can put out 160 HP, but weighs over 300 pounds.
8.6 times the power-to-weight?!
The Following 3 Users Say Thank You to Xist For This Useful Post:
freebeard (01-30-2022), Gasoline Fumes (01-30-2022), RedDevil (02-06-2022)
Old 01-30-2022, 02:10 PM   #2 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I agree it doesn't sound possible. I'll watch the videos later. Can I reserve an Elio with that engine?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 01-30-2022, 02:17 PM   #3 (permalink)
I don't understand how the cool side and hot side are connected, but it strikes me as similar to the Scuderi/Entry Combustion designs that separate the two, on a crankshaft.
Also don't understand why the two rotors are hollow.
Old 01-30-2022, 04:03 PM   #4 (permalink)
Good find...
More info and videos here.
https://www.astronaerospace.com/
Edit.
The first 30 minutes of this video are very interesting...
https://youtu.be/_LkkjYParp4?t=170
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
The Following 2 Users Say Thank You to redneck For This Useful Post:
freebeard (01-30-2022), RedDevil (02-06-2022)
Old 01-30-2022, 04:21 PM   #5 (permalink)
I went back and Thanked Xist too.
So it is a Brayton cycle, just translated away from the rod and wheel paradigm. I still don't understand the hubless design, but maybe it has something to do with the aviation focus.
Note: This technology is projected to be capable of flying through a flock of birds, volcanic ash, smoke, and sand without skipping a beat, as well as the highest altitude flying capability that exists. Also does not require rotor seals at all. Tight tolerances and high RPMs solve that problem, not enough time for the air to leak when running!
Neat! Especially as it's self-cooling.
Old 01-30-2022, 04:40 PM   #6 (permalink)
Aerospyder - '00 Toyota MR2 Spyder
90 day: 41.98 mpg (US)
Simme - '83 IFA Simson Suhl S51
Motorcycle
90 day: 76.59 mpg (US)
What's next, someone brings up RWTHs IKV engine?
Old 01-30-2022, 04:56 PM   #7 (permalink)
Yes Aviation.
Think rocket engine...
Hollow rotors with added bell shaped nozzles for thrust. (afterburners)
Run as a internal combustion engine as high as possible (100,000 ft. ?)
then rotate engine to utilize nozzles with Liquid oxygen and hydrogen when there’s no atmosphere...
Very cool... 😎
Disclaimer...
But...
Old 01-30-2022, 05:09 PM   #8 (permalink)
duckduckgo.com/?q=RWTHs+IKV+engine&ia=web
They would have to sort out what your referent might be.
redneck -- Single stage to orbit, like the UK Skylon? I was thinking more along the lines of Jetoptera.
If it exhausts into the central flow does that make it a complicated pulse jet?
Edit: quote: "It's fun to work with people who know what they are doing." Matthew Riley, Astron Aerospace
2nd edit: Okay, I need to get my 3D printer up and running. A proof of concept model seems achievable, but with lost PLA casting techniques, a hubless bicycle wheel motor is within possibility. You couldn't sell them because patents, but one could make one's own.
Since they spin in opposite directions the air flow should be opposed, so a rear wheel motor could blow into 90˚ elbows. ....with afterburners!
Old 01-31-2022, 05:14 PM   #9 (permalink)
emissions
Perhaps they didn't get the memo about carbon dioxide.
And competing against 'engines' with a BSFC-e of 0.0795 lbs/ bhp-hr should be interesting.
'I pity the fool!' Mr. T
Old 01-31-2022, 05:44 PM   #10 (permalink)
Perhaps they did. Did you catch the part about Hydrogen?
aerohead (01-31-2022)
